stuck under 2000rpm....another prob! help?
Old Jan 13, 2002 | 11:49 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
hummmm
on my way to the Meet today all of a sudden my car cut out...the rpm's would go over 2000. felt like it was hitting the rev limiter. Im sure its not a mechanical prob cause later it worked again. Somehow the ECU is cutting out around 2000rpm. Possible cam or crank sensors would be my guess. I pulled the codes at home and its the same O2 sensor and EGR codes ive had forever. whats going on? i swear the car is cursed....this sucks.
Old Jan 14, 2002 | 01:21 AM
emax02's Avatar
Re: stuck under 2000rpm....another prob! help?
Originally posted by Turbo95Max
hummmm
That sounds like limp mode, only thing is I don't think 95's have limp mode, hmm.. Ahh, I have no clue what could cause that, how about "false air" after the intake, I think that would make your car idle real high and act strange. Check for air leaks. If the problem is intermetent it's probably something electrica though.
Old Jan 14, 2002 | 02:43 AM
Nismo87SE's Avatar
I would say the MAF needs to be looked at. In my maxima and se-r if I was to unplug the MAF the engine wouldn't rev over 2000rpm, nor would it idle. Try unplugging the maf to see if the same conditions happen if so then you've found part of the problem.
Old Jan 14, 2002 | 03:52 AM
ToYLeT902's Avatar
JET Speed Lab
you need a new turbo.
Old Jan 14, 2002 | 05:09 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
a bigger one at that.
Old Jan 14, 2002 | 06:08 AM
MaximaRider's Avatar
i can't beleive you can run into so many problems for a simple/impossibly accomplishable turbo kit. I have been reading up on your maxima's history for the past couple of years and i am still astonished that its not 100% yet.
Old Jan 14, 2002 | 07:20 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
And some of you guys are hoping for a trouble free turbo kit.
Old Jan 14, 2002 | 07:22 AM
Sprint's Avatar
maybe its the people making "THAT" kit and not the kit per say
Old Jan 14, 2002 | 07:27 AM
Y2KevSE's Avatar
I hope the kits do come through though (I might even switch over ).
We'll see an influx of "Blown tranny", "Slipping clutch", and "Blown motor" threads because of all the greedy boost ******.
Old Jan 14, 2002 | 07:32 AM
Sprint's Avatar
their are successful Turbo Max's running around
check the NE Forum
Old Jan 14, 2002 | 07:37 AM
Y2KevSE's Avatar
check the NE Forum
Yeah, I read that thread (but haven't been keeping up with it).
You guys know his stats yet?
Old Jan 14, 2002 | 07:45 AM
Sprint's Avatar
no but if Hogan is only 1 car slower than him.. he must be running like -10 PSI
Old Jan 14, 2002 | 10:25 AM
Turbo95Max's Avatar
hummmm...sucks...at least Lynn's car is here and i can steal i mean borrow parts off of it temporarily. here we go again....ugghh
Old Jan 14, 2002 | 10:29 AM
Jeff92se's Avatar
I'm needing a caw
Hmmm I remember when I blew some of my pressure side hoses off. It ran similar to what you describe. Check and reclamp all your hoses. Boost leaks are a major pain. Then again, swap mafs and see if that cures it.
Old Jan 14, 2002 | 10:54 AM
Turbo95Max's Avatar
i dunno...it doesnt seem like its a mechanical type prob. Ive had pressure side hoses come off before and it didnt do what its doing rite now. Its like the ECU is keeping the car from revving higher...caused from what i dunno.
Old Jan 14, 2002 | 11:30 AM
InSaNiUm
Boy, that surely sucks... Perhaps you should look into an Infiniti qx4. I heard that solves a lot of problems as far as maximas not working... hmmm....
Old Jan 14, 2002 | 11:48 AM
Eric L.'s Avatar
Hey Matthel,
Sounds like the limp mode alright, but if I remember, limp mode prevents the engine from revving over 3000RPM, not 2000. I don't have it with me now, but check the FSM to see what would cause the ECU to go into limp mode. Several off the top of my head include excessive wheel spin (for automatics), overheating, and multiple engine misfires (deterioration of exhaust quality).
BTW, replaced my LH O2 sensor this past weekend. Mileage back up again! Before, I got 14MPG on the highway with the bad O2 sensor.
Old Jan 14, 2002 | 11:50 AM
Y2KevSE's Avatar
Go away... we don't talk to supercharged QX4's.
Old Jan 14, 2002 | 12:09 PM
Sprint's Avatar
SC QX4 .. whta does that run? mid 15's?
Old Jan 14, 2002 | 12:30 PM
Y2KevSE's Avatar
Let's not talk about his dyno.
Old Jan 14, 2002 | 01:23 PM
Turbo95Max's Avatar
Originally posted by Eric L.
Hey Matthel,
thanks Eric
ill look into it. Jeff metioned that he remembered one of the codes we reset while on the side of the road. it was the crank position sensor. Since Lynns car is here im gonna borrow his and see wassup.
Old Jan 14, 2002 | 01:58 PM
95emeraldgxe's Avatar
try getting a new ECU......the g-force maybe?
Old Jan 14, 2002 | 04:14 PM
Sprint's Avatar
he has boost.. its not as easy as going to pick one up from the store..
Old Jan 14, 2002 | 04:25 PM
InSaNiUm
Hahaha, seriously... I'll get it fixed soon enough...
Old Jan 14, 2002 | 04:27 PM
Y2KevSE's Avatar
Riiiiiiiiiight. Get a BOV installed while you're at it.
Old Jan 14, 2002 | 07:12 PM
TintDaMax's Avatar
Matthel, same thing happened to me. I would have said something at the meet, but the correlation didnt click in my head until now. Of course I dont have a turbo, but I when i was messing with my g-force ecu it happened. I would bet 100 bucks that your TPS(throttle position sensor) is busted. I paid like 100 and something for mine from the dealer and after I got it installed, the car worked perfectly. Mine would not go over 2000 either, so i bet you have the same problem. You could run the ECU trouble codes and see if thats really the problem I think.
DPW
Old Jan 14, 2002 | 08:58 PM
Turbo95Max's Avatar
DPW
hummmm sounds interesting...ill check it out. thanks James
i did get TPS sensor before but not recently. but my car is so messed ive basically had every single trouble code imaginable.
Old Jan 15, 2002 | 12:26 AM
Turbo95Max's Avatar
hummmmm
so turns out the bolt holding the crank sensor actually broke. so we're thinkin yea we found the prob, extract the old bolt and check the crank sensor, its ok, so we put it back in and still same prob....crap.
Old Jan 15, 2002 | 02:04 PM
hummmmm
crank sensors suck. i had prob with mine before i sold my 95.
Old Jan 15, 2002 | 02:05 PM
Sprint's Avatar
Originally posted by dmbmaxima88
crank sensors such. i had prob with mine before i sold my 95.
i heard MattC wants to such you
Old Jan 16, 2002 | 04:45 AM
Old Jan 16, 2002 | 04:50 AM
Sprint's Avatar
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
