HKS din panel modified to fit autometer gauges. Pictures
Old Jan 14, 2002 | 07:28 PM
1MAX2NV's Avatar
Took me about 30mins to enlarge the holes with a dremel.
Scroll down to see pictures.
Old Jan 14, 2002 | 07:30 PM
Sprint's Avatar
will have to cut and paste into new window..
Old Jan 14, 2002 | 07:32 PM
deezo's Avatar
Nice pics Tony.
This is one of them...
1MAX2NV's Avatar
Old Jan 14, 2002 | 07:35 PM
deezo's Avatar
Nice and clean!
Old Jan 14, 2002 | 07:37 PM
s1rch's Avatar
looks good, nice and clean.
wanna do mine ?
Old Jan 14, 2002 | 07:38 PM
1MAX2NV's Avatar
Old Jan 14, 2002 | 07:42 PM
s1rch's Avatar
didn't I say that
Originally posted by deezo
Nice and clean!
we must be on the same mental wavelength.
Old Jan 14, 2002 | 07:54 PM
RedMax95's Avatar
Re: didn't I say that
nice
Old Jan 14, 2002 | 07:56 PM
NotNew!!NewSN!!'s Avatar
where are u locating those guages in ur max? obviously not on the pillar, under ur stereo? i was itching to do the same thing, please enlighten me, cuz i have a dual pillar guage, but usually u use those things for boosting and nos, id rather hide, my monitoring guages, thanks
Old Jan 14, 2002 | 07:58 PM
matt calder's Avatar
hey Tony, have you got your water temp guage hooked up yet, I am interested in seeing what kind of temps you are getting in comparison to mine.
also how hard was it to hook up the sender the way you said you were going to do it. Do you think maybe you could take a pic of it sometime (if you are not to busy) and post here or send me an email.
thanks
looks good by the way.
Old Jan 14, 2002 | 08:06 PM
theblue's Avatar
welcome to the club, glad to know there is a non-custom solution out there.
Old Jan 14, 2002 | 08:18 PM
1MAX2NV's Avatar
Not yet. I got the basic parts ready. Just need to stop by the machine shop and get them to weld on the new fitting. Here are some pictures. I got the HKS water temp sensor pipe. The HKS fitting currently on it is metric and it's too big.
thanks
is it possible to do these setups while keeping the stock double din? say cutting into the lower portion flip open slot, just wonderin if anyone has done it
Old Jan 14, 2002 | 08:20 PM
1MAX2NV's Avatar
Yes, the lower flip open slot is just a din size opening. If I want, I can just bolt up my HKS din panel in that slot.
Old Jan 14, 2002 | 08:25 PM
Thanks alot Tony
That pipe looks pretty cool. Where did you find that at. Any old shop that sells HKS gauges? I am wondering if you are going to get any different readings than me, should be interesting.
Old Jan 14, 2002 | 08:30 PM
1MAX2NV's Avatar
It's a HKS part. Most shops don't carry it, but it can be special order. I got the 34mm O.D.
http://www.hksusa.com/products/?id=867
Thanks alot Tony
Old Jan 14, 2002 | 08:32 PM
somehow it doesnt look like it will fit, what are the dimensions of ur guage cluster there? and better yet, how much?, and those are interchangeable guages right? thanks buddy, sorry to bombard u with questions
Old Jan 14, 2002 | 09:03 PM
1MAX2NV's Avatar
The panel is about $25. It's the size of a din size radio. Check these pictures for comparison.
Old Jan 14, 2002 | 10:26 PM
Chunger's Avatar
My other car is a Hybrid
Nice info... I have the Voltmeter and Oil Pressure gauges sitting in my room... just needed to pick out another gauge... I see you like the Ultra-Lite line too. I gotta wait until I plumb in an oil cooler kit for my Oil pressure sender.
Are you going to get the 3 gauge warning box? It's only about $70 and will warn you when any of the 3 fall below a settable threshold.
Old Jan 14, 2002 | 10:37 PM
Cumalot's Avatar
That setup looks sweet. Much better setup than a guage pod setup. Very clean. Then again, everything about your car is sweet and clean. So, we shouldn't be too surprised.
Old Jan 15, 2002 | 07:27 AM
ejj's Avatar
ejj
Tony,
Where did you get it from? That's exactly what I'm looking for!
Old Jan 15, 2002 | 07:38 AM
delio's Avatar
I did the same thing with a Blitz panel... Dremels rule.. Now I have my Oil Pressure Guage in the Din opening... My Panel only fits 1 guage, then also fits 2 1/4 DIN items...the HKS turbo timer is in one and the Fields Fuel Controller will weasel it's way into the other one.
Old Jan 15, 2002 | 08:08 AM
1MAX2NV's Avatar
There is a HKS groupbuy on www.groupbuycenter.com I just got it off that vendor.
Originally posted by ejj5875
Tony,
Old Jan 15, 2002 | 09:08 AM
guido_sst's Avatar
Looks very clean! I definitely need to do this one of these days...
Old Jan 15, 2002 | 09:15 AM
clee130's Avatar
Sweeeeeeeet!
Old Jan 15, 2002 | 09:29 AM
Synki's Avatar
Its looking good Tony.
Now i dont know if i should remove my 3 gauges off my A-Pillar and relocated down to the DIN for a more sleeper like look.
Old Jan 15, 2002 | 09:33 AM
95emeraldgxe's Avatar
very nice setup!!!!!!!
Old Jan 15, 2002 | 09:53 AM
guido_sst's Avatar
Do both! Can never have too many gauges...
Old Jan 15, 2002 | 10:12 AM
MaximaRider's Avatar
i can't wait to do that with mine but is there anyway i can get indiglo gauges, like that stillen boost indiglo gauge jane97se had?
Old Jan 15, 2002 | 10:34 AM
ejj's Avatar
ejj
I'm doing both. FP and EGT on the pillar, and eventually AF, oil pressure and oil temp under the radio.
Old Jan 15, 2002 | 11:43 AM
is there a premade double or triple guage din box from hks, or did u get that single din one with the link, and just dremel out the holes? very interested wanted to know how u did it, and what size and company guages are u using?
Old Jan 15, 2002 | 12:37 PM
1MAX2NV's Avatar
The HKS I got is premade. The problem is the holes are 46mm. Too small for autometer gauges, so I busted out my dremel with a sanding drum. 30 mins later, the not so perfect larger circles were made.
Old Jan 15, 2002 | 01:55 PM
wicked1044's Avatar
i can't see the pics...
Old Jan 15, 2002 | 02:29 PM
1MAX2NV's Avatar
Scroll down on the first page.
Old Jan 15, 2002 | 02:53 PM
BlkCat
I just see "Image has expired" instead of pics.
Old Jan 15, 2002 | 03:08 PM
deezo's Avatar
True dat!!!
Old Jan 15, 2002 | 03:33 PM
1MAX2NV's Avatar
Oh well...i'm too lazy to find a picture server.
nm
Old Jan 15, 2002 | 05:01 PM
ejj's Avatar
ejj
Re: Oh well...i'm too lazy to find a picture server.
nm
Tony, could you email them to me? I'd love a copy, plus I can host them for everyone else to see.
Let me know, janus@rochester.rr.com
Old Jan 15, 2002 | 06:15 PM
ejj's Avatar
ejj
The pics are located here:
http://www.rit.edu/~ejjfac/maxima/HKS_DIN/
