Do cali-spec 2000 Maxima 5-speed puts down less power than fed-spec?
Old Jan 18, 2002 | 08:04 AM
Dany's Avatar
I have 2000 Maxima 5-speed cali-spec and it doesn't seem like I can get high 14s or somewhere near those times for 1/4 run that some people on this board were getting for stock 2000 5-speed Maxima. My car just seems slow.
Yesterday, I ran with Integra GS-R, it was the newer body type, and that car is pretty fast.
He didn't beat me, but I couldn't pass him either.
I checked the specs on that car. And it got NO torque. That is unbelivable that Honda gets those cars to go that fast with almost no torque. And hp on GS-R is only like 170hp.
Old Jan 18, 2002 | 09:55 AM
PhatGuy
If your stock and even with a good GS-R driver your car is fine IMO. No real power diff between cali and fed. Been swapped with no gains either way as far as I know.
Old Jan 18, 2002 | 11:09 AM
SuDZ's Avatar
Re: Do cali-spec 2000 Maxima 5-speed puts down less power than fed-spec?
He may have a fwe less HP but also alot less weight. They weigh in at around 2800 Pounds. Not sure what the 5th gens are at but they are heavier then 4th's and we only have about 3200 pounds. Thats why you were even most likely. He had less weight to push down the road.
SuDZ
Old Jan 18, 2002 | 09:31 PM
theMax's Avatar
Search for some dyno's here.
I looked at this after I found out I had a cali spec. what I found is peak HP is the same for both BUT the bands were not in the same for both. At one point the cali spec has 10 less ftlbs of torque!! (I need a udp!) Not sure how much this will affect, plus are your wheels stock? The stock 17's are heavy.
Old Jan 18, 2002 | 10:30 PM
My 4DSC
00' fed emissions... 14.9 @ 94.75 mph 100% stock (on 18" rims)
Old Jan 18, 2002 | 11:31 PM
DaEnigma's Avatar
From what I have seen there is about 1-3hp and 2-4ftlbs difference at most... Usually there is no difference that can be seen. The 99-2001 CA/NLEV exhaust (Manifold to last flange before the muffler) is exactly the same from what I have seen.
And as usual this is IMHO
Old Jan 19, 2002 | 07:01 AM
UMD_MaxSE's Avatar
Got Bent?
one main difference is the intake manifold in the cali spec vs fed spec model. The Cali spec model has some swirl control valve that is part of the intake manifold. While this may not be a big thing, it may hinder the intake manifold slightly.
Old Jan 19, 2002 | 08:41 AM
95emeraldgxe's Avatar
cali may lose just a few HP......nothing too major
Old Jan 19, 2002 | 11:52 PM
irvine78's Avatar
if u raced him off the line, u'll take him down so hard he'll cry on his way home beating his head against his steering wheel and wondering why he is such a pathetic loser... on the other hand, if u were racing him starting around..60-70mph...it can be very close especially if ur car's stock..
halfpol
Oct 17, 2022 12:16 PM
jholley
Aug 11, 2015 09:38 AM
sc10692
Aug 9, 2015 09:37 AM
niZ
Aug 7, 2015 10:18 PM
kjm900r
Aug 5, 2015 07:14 AM
