Y-pipe issue
Old Jan 29, 2002 | 08:42 AM
Str8ridin's Avatar
Y-pipe issue
Ok, here's the situation. I bought the pipe and installed it only to find is was defective by being welded uncorrectly thus posing a fittment issue. The manufacturer said to remove it and send it back so they can 'fix' it and return it to me. I just paid a total of $160 intsalling it then un-installing it just because they sent me a defective pipe. My question is, should they reimburse me for that or is it my problem that I bought a defecive pipe from them? When I get it back, I'm gonna have to pay a total of $240 out of my pocket to install the damn thing!
-str8
p.s. please don't flame for not installing it myself. I don't have any tools now!
Old Jan 29, 2002 | 08:52 AM
Sprint's Avatar
nope.. you will have to bend over like i did..
try ..
Warpspeed Y Pipe $330
shipping $20
Install $80
$420
flex section blows...
$420
Cattman Y Pipe (shipped) $405
Install $80
$905
Sold Warspeed defect pipe - $120
My Y Pipe Experience? $785
Old Jan 29, 2002 | 09:00 AM
Str8ridin's Avatar
[QUOTE]Originally posted by SprintMax
[B]nope.. you will have to bend over like i did..
Ouch....hope you used vasaline..
So, that's how it is, huh? Man, that just pi$$es me off...
Old Jan 29, 2002 | 09:01 AM
Sprint's Avatar
[QUOTE]Originally posted by Str8ridin
[B]
I am sure Bryan from the Northeast paid out his a$$ when his flex section his warspeed pipe blew and he had to buy a new pipe and all that.. probably paid the same i did.. maybe more..
Old Jan 29, 2002 | 09:13 AM
«§»Craig B«§»'s Avatar
my Y experiences
bought WSP mandrel bent pipe (only used for a week), included new flex section and all gaskets - $150
shipping - 20
install - couldn't get the bolts loose at all myself so I went to a local shop - 50
total = $220 with no problems whatsoever and I needed to replace my old, leaky stock pipe anyway
Old Jan 29, 2002 | 09:49 AM
redmaxpa007's Avatar
i SeE what you did therE
that is why you do installs yourself....
Old Jan 29, 2002 | 09:51 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
well not everyone's father has a lift
Old Jan 29, 2002 | 09:55 AM
actually, i did the y,b, and cat install at tilleys99 house...
so........
but you are correct...
Old Jan 29, 2002 | 10:04 AM
SuDZ's Avatar
You have a lift? At your house? That is so great and convienient sounding.
SuDZ
Old Jan 29, 2002 | 10:11 AM
SuDZ
my dad is a mechanic.. so he has a lift at his house and his work is 15 minutes from his house .. so i have access to a full automotive shop with my very own mechanic...
Old Jan 29, 2002 | 10:17 AM
SuDZ's Avatar
Not a bad deal at all.
SuDZ
Old Jan 29, 2002 | 10:20 AM
Sprint's Avatar
so it the mechanical knowledge skips generations? look at that.. you learn something new everyday.. well something your new baby has to look forward to eh jeff?
Old Jan 29, 2002 | 10:34 AM
you know darren.... you can be such an sometimes...
but that is ok.. i hope to have the new baby girl up to par with fixing cars...
Old Jan 29, 2002 | 11:43 AM
dwapenyi's Avatar
Wow, and I was bummed by my Y pipe issue.
I got my Y pipe from cattman on special $159 One day just perusing the site and saw it in the specials sectin. I JUMPED on it. Got the last one.
Had my mechanic install it and replace all 3 O2 sensors. Nothing was wrong with the original ones, but at 100K miles, may as well.
Get my car back, everything is fine, feel a great difference. But later on, I get a check engine light. 0702. It's pointing to the O2 sensors. Looks like one of them may be defective.
I haven't fixed in a couple of months. I reset my ecu and the check engine light returns every week and a half or so. I can make it return much more quickly if I drive like a granny. If I drive hard all the time, the check engine ligt never appears.
Weird
DW
Old Jan 29, 2002 | 12:11 PM
ericdwong's Avatar
Re: Y-pipe issue
You dont need a lift to do anything...except for maybe welding on subframe connectors. Of course it makes it alot easier. I have done all my projects on my car (including dropping the transmission three times in the max alone, clutch job, Y pipe install/removal a few times, B pipe install and a few others) with nothing more then one hydraulic floor jack, 4 jack stands, and various hand tools (no air tools).
As for Y pipes here is what happened to me. It took forever and alot of swearing just to get the thing on in the first place. Then, a few months later the damn flex section busted. The above 2 were both caused because the cat flange was rotated off, so this caused the entire weight of the exhaust system to twist on the flex. After a while it just busted open. So.... I had to ship the thing back to arizona. When it came back, the exact same problem happened with the flange being off. So back once again. Finally when I got it back, it fit perfectly. Phew. Total time wasted, probably 3-4 months. Don't want to think about how much I paid for shipping out of there.
Mar 12, 2020 12:06 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
