Converting rubber fuel lines to ss braided line?
Old Feb 1, 2002 | 10:58 AM
1MAX2NV's Avatar
Converting rubber fuel lines to ss braided lines?
Is this what I need to turn the hard fuel lines into a AN fitting? I guess I would have to flare the hard fuel lines.
http://store.summitracing.com/partde...504&part=10025
This way I can remove all the rubber hoses.
Old Feb 1, 2002 | 11:14 AM
Albertt's Avatar
Tony: Try posting at the 3rd Gen board, several of them might know. nm
nm
Old Feb 1, 2002 | 11:18 AM
Jeff92se's Avatar
I'm needing a caw
Tony you should really be talking to the muscle car crowd or maybe Mardigrass or someone. The muscle car guys have been replacing their rubber lines w/ SS for decades. It's probably an real easy question for them. Should be at least a few in the local yellow pages.
Old Feb 1, 2002 | 11:32 AM
Lordrandall's Avatar
Tony, did you get an IS300 and I missed it?
Old Feb 1, 2002 | 11:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
damn jeff...joo a rookie...
anyway...
tony...from the hard line you need to get a compression fitting/adapter. figure out what size hard tubing and get the correct adapter. from that you can attach the standard AN fitting from your braided line.
Old Feb 1, 2002 | 11:41 AM
Jeff92se's Avatar
I'm needing a caw
Nice info
anyway...
btw you suck
Old Feb 1, 2002 | 11:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
Nice info
btw you suck
gee thanks jeff...
tony..
that's the pipe adapter..the taper side is the AN end..and the straight threaded size you need to screw into a compression fitting.
good luck with it because the plumbing is not cheap at all. at least you're not going to the fake sleeve on the rubber hose direction.
Old Feb 1, 2002 | 11:59 AM
1MAX2NV's Avatar
Danny...thanks for the info. The only reason I'm going with braided line is because of my new SARD FPR. I have to mount the regulator a good distance away from the original location. I don't want to risk using regular FI hoses. The possibility of it being kinked or pinched. You don't happen to have a picture of what a compression fitting looks like do you?
Old Feb 1, 2002 | 12:03 PM
maxmizd27's Avatar
Tony,
Why do you need to use an AN style fitting? Is this what your big brake kit takes? I have the Goodridge lines on my car and they have the same female thread size as the stock piece that was already flared onto the end of the stock ridgid line. I just had to screw both ends of the braided line on and that was it.
Old Feb 1, 2002 | 12:49 PM
1MAX2NV's Avatar
For the fuel lines. I found a -6AN fuel rail adaptor.
Originally posted by maxmizd27
Tony,
Old Feb 1, 2002 | 01:03 PM
maxmizd27's Avatar
Duh! I can read. Never noticed that you said "fuel" and not "brakes." Don't mind me. I'll go back to sleep now.
Old Jun 12, 2002 | 12:45 PM
ejj's Avatar
ejj
Tony - Did you ever change all your fuel lines to braided ones?
Old Jun 12, 2002 | 02:55 PM
1MAX2NV's Avatar
I have all the fittings and lines. I'm just too lazy to do the work right now. Maybe later on this year.
Old Jun 12, 2002 | 03:19 PM
Chunger's Avatar
My other car is a Hybrid
...I'm just too lazy to do the work right now...
HAHAHAHA! We know how that is!
Old Jun 12, 2002 | 04:10 PM
ejj's Avatar
ejj
How does the braided line fit onto the existing hard lines and the fuel filter...I just can't picture it.
I haven't done anything like this before...but I'll be installing a new fuel pump and FPR in the next week or two, and though this was a good idea.
Thanks.
Old Jun 13, 2002 | 09:20 AM
Thanks.
Look up at DanNY's post....
Old Jun 13, 2002 | 09:44 AM
1MAX2NV's Avatar
Compression fitting or you could use hose clamps that are design for SS braided lines.
Thanks.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
09maxshawn11
Sep 30, 2015 10:28 AM
