Transmission cooler type query
Old Jul 7, 2019 | 09:55 PM
Jagalag's Avatar
So I'm thinking of installing a transmission cooler on one of my cars. There are the more efficient "plate and fin" designed coolers, but these are all painted, versus the "tube and fin" design, which a bare aluminum. Doesn't the powder coating or regular paint they use make heat dissipation less efficient, than if it was the bare metal surface in contact with passing airflow? Thanks.
Old Jul 9, 2019 | 10:32 PM
chrome91's Avatar
what kind of environment are you in? if youre bypassing the OEM cooler in the radiator and going purely external aftermarket, you risk overcooling the trans fluid in colder temps/winter. if youre in the desert/putting it inline with the radiator cooler, should be okay
Old Jul 10, 2019 | 08:45 AM
Jagalag's Avatar
Central Texas. Not much worry about the cold winters, and yes, plumbing it inline AFTER the factory trans cooler inside the radiator. How about the powder coating or paint though? Is it mainly for aesthetic purposes? If so, then I think it might reduce cooling efficiency...what you do think?
Old Jul 10, 2019 | 12:12 PM
MadMax07SL's Avatar
It's just a thin layer, it's not insulating much. Especially when you consider that it's trying to displace heat in a hot engine compartment. It's nominal.
Old Jul 10, 2019 | 01:41 PM
chrome91's Avatar
you should be fine then especially if its inline after the rad cooler. powder coating/painting as said has limited if no difference in heat
allmazda
Feb 21, 2018 04:46 AM
ffcbairn
Feb 11, 2013 04:01 AM
NewfoundlandDud
Mar 3, 2008 10:37 PM
Enduro
Jan 26, 2001 05:09 PM
