2001 I30 Blinking D light
Old Oct 4, 2021 | 10:48 AM
James Munsell's Avatar
First I'm sorry if this is in the wrong area but I can't find infinity.
The occasional blinking D light started a few weeks ago and when it happens it won't shift however if you pull over and turn the car off and restart it it shifts just fine. Thanks for the help in advance.
Old Oct 6, 2021 | 07:30 AM
Must not be a very active forum
Old Oct 7, 2021 | 03:10 AM
I35GEEK's Avatar
A blinking D light usually means that you have an issue with the transmission. I would do the basics first. Check transmission fluid level and condition. Have you plugged in an ODB scanner to see if there are codes?
Old Oct 7, 2021 | 11:30 AM
I have a few CAT codes that have been there for years and I now just lately see a P0505 IAC code pop up. Idle is OK but kid has complained it's been a little sluggish more then likely because of the IAC issue. Nothing pertaining to transmission issues however I read that it's not uncommon to see no codes with the D light blinking issue. Fluid is old old old.
Old Oct 8, 2021 | 12:27 PM
TallTom's Avatar
Post this in the 5th gen forum section and you may get quicker results.
ershi30
Jan 4, 2006 07:47 PM
Asian_N02
Feb 11, 2004 06:41 AM
