Melted Tensioner Pulley on V2 Supercharger
Old Feb 11, 2002 | 12:21 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Old Feb 11, 2002 | 12:22 AM
Y2KevSE's Avatar
Old Feb 11, 2002 | 12:23 AM
Y2KevSE's Avatar
Old Feb 11, 2002 | 12:25 AM
Y2KevSE's Avatar
Old Feb 11, 2002 | 12:26 AM
Y2KevSE's Avatar
Old Feb 11, 2002 | 12:27 AM
Y2KevSE's Avatar
Old Feb 11, 2002 | 12:29 AM
Y2KevSE's Avatar
This is NOT off my car... it's off a 4th gen.
And I did NOT take these pictures... my hands were dirty.
Old Feb 11, 2002 | 01:19 AM
mingo's Avatar
UH OHhhhh who's car???? not janes rite??
Old Feb 11, 2002 | 01:31 AM
mozy's Avatar
gosh kev, I thought your sc went *p00f*
scared me there. who's car is it? (don't tell me jane...)
Old Feb 11, 2002 | 02:45 AM
NickStam's Avatar
Re: !!!
get the ones that don't melt
Old Feb 11, 2002 | 07:24 AM
Y2KevSE's Avatar
Re: Re: !!!
Trying.
If it's not my car, who's are is it?
Old Feb 11, 2002 | 07:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: !!!
Originally posted by Y2KevSE
Trying.
trying enh?
guess that'll slow down performance a bit enh?
Old Feb 11, 2002 | 07:36 AM
Y2KevSE's Avatar
Re: Re: Re: Re: !!!
Originally posted by DanNY
trying enh?
Get the email?
Old Feb 11, 2002 | 07:39 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: !!!
Get the email?
yup..it's different than what i have at home..mine is umm bigger
u got a spare "peewee" (ask jane) to loan for a week or so?
Old Feb 11, 2002 | 08:09 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: !!!
Which one you need? With or without rails?
Guess Stillen switched to different pullies when they converted from V1 to V2.
Old Feb 11, 2002 | 08:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Re: !!!
with rails please.
Old Feb 11, 2002 | 08:25 AM
eric93SE's Avatar
So what was the problem...Wrong pulley?
If the tension on the belt was too great, it would ruin the bearing then it could have overheated.
Old Feb 11, 2002 | 08:50 AM
Y2KevSE's Avatar
Re: So what was the problem...Wrong pulley?
This has happened to a lot of V2 owners. I'm not saying over-tensioning is not the problem, but with so many melted pulleys one has to think that they're defective.
Old Feb 11, 2002 | 08:51 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: !!!
with rails please.
PM me your addy...
So I know where I have to go to steal your car.
Old Feb 11, 2002 | 09:19 AM
BlkCat
I've had my V2 since Oct,2000 and mine hasn't melted yet but I think I'll replace it now. Where can I order one for my Max?
Old Feb 11, 2002 | 09:22 AM
Y2KevSE's Avatar
A couple .orgy members are working on aluminum pulleys. Hang in there...
Scary sight, eh?
Old Feb 11, 2002 | 11:49 AM
mozy's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: !!!
Old Feb 11, 2002 | 06:27 PM
Chebosto's Avatar
RIceD OuT moDErAtor
this post brings back baddddd memories.
i still have the remains of my melted pulley. *shudder*
Old Feb 11, 2002 | 09:40 PM
Kevin Wong's Avatar
Yeah, maybe you guys should look into a new pulley supplier. I know Hayden carries all sorts or aluminum pulleys and I'm sure you can find a number of other manufactuers. I guess, take the measurements and ask them if theirs will hold up to the SC.
But then, I think before you go through all the trouble, you should really find out what's causing the pulleys and belts to fail. Too much heat, material integrity, balancing, or something. I think Stillen should get down to the bottom of this, but I wouldn't hold my breath.
Old Feb 12, 2002 | 08:25 AM
sparkymax96's Avatar
Solution:
Old Feb 12, 2002 | 08:32 AM
Y2KevSE's Avatar
Originally posted by sparkymax96
Solution:
Idler pulley with rails (19mm bolt).
You can probably use that as your tensioner pulley (if you have a V2) if the tensioner pulley spacer fits in the hole.
Old Feb 12, 2002 | 03:02 PM
My 4DSC
Another one bites the dust!
Old Feb 12, 2002 | 03:16 PM
Y2KevSE's Avatar
Re: Another one bites the dust!
Originally posted by My 4DSC
Not your former kit... it's still intact.
BlkCat
Okayyy...so where can I go to get that piece?
Old Feb 12, 2002 | 08:07 PM
NickStam's Avatar
i don't think they're are for sale to the public yet
Old Feb 13, 2002 | 06:39 AM
Y2KevSE's Avatar
Couple members are currently working on them. Just hang in there.
Old Feb 18, 2002 | 01:40 AM
Lyt97SC
I have 1 Aluminum V2 Pulley for sale (possibly 2). never been used. email me at Lyt77@aol.com
Old Feb 19, 2002 | 11:05 AM
BlkCat
Keep us posted! Thanks!
Old Feb 19, 2002 | 05:27 PM
ptatohed's Avatar
Licensed to Spell
:o)
Well, what rule of them are you guys using for belt tension? In the Stillen instructions, I had absolutely NO idea what they were talking about. They said something like 'get the belt 90^ with your thumb and forfinger'. What the h. is that supposed to mean?! So, all I did was whip out the Haynes and Chiltons manuals and followed their rule for drive belts/serpentine belts. They said something like "If the distance from the center of pulley to center of pulley is between xx" and yy, use zz" for deflection". And they showed a pretty good pictures of using one ruler for a straight edge and the other to measure the defelection. That's what I did. Following what they said, I think I allowed for 1/4" deflection (measured at the lowest/most convenient point). How are you guys choosing your drive belt tension?
Old Feb 19, 2002 | 10:50 PM
Y2KevSE's Avatar
Use your index finger and thumb... grab the belt between the crank pulley and AC pulley... turn the belt away from you... if you can turn it greater than 90 degrees then it is too loose... if you can't turn it to 90 degrees then it is too tight.
Old Feb 20, 2002 | 01:35 PM
ptatohed's Avatar
Licensed to Spell
:o)
Oh, I see what your saying. O.k. Deflection-wise though, what should it be?
Old Feb 20, 2002 | 01:45 PM
Y2KevSE's Avatar
Re: :o)
I do it the ghetto way.
Old Feb 20, 2002 | 04:02 PM
The New CLIMAX's Avatar
Re: Re: :o)
you mean the Keving way
Old Oct 6, 2002 | 05:15 PM
JAY25's Avatar
Re: Re: Re: :o)
I would not get a idler w/rails! why, that was one of the causes of a shreded belt I fixed on a supercharger.
Old Oct 6, 2002 | 10:06 PM
Y2KevSE's Avatar
Re: Re: Re: Re: :o)
Idler doesn't come with rails... tensioner does.
