VB mod is in but.......
Old Feb 21, 2002 | 12:27 AM
jdmmax's Avatar
hey thanks to don VB mod went like clock work sort off. he delivered as promised. very pleasant to deal with. but one question how come i can't chirp secound????? just wondering.
Old Feb 21, 2002 | 12:42 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: VB mod is in but.......
maybe cuz u put in the VB into an already worn out tranny?
i remember when we took out Skimax's VB and put it in Buss95max's tranny. it chirped 2nd all the time and NEVER did in Ski's.. even tho Ski has a 97, buss a 95, just that buss' tranny was in much better condition and much stronger..
oh well.
--ches
Old Feb 21, 2002 | 12:51 AM
Shadow's Avatar
Your tranny is already worn out like Cheston said. I can't chirp second either, but that's because at full boost, the tranny really doesn't hold the power that well.
Old Feb 21, 2002 | 10:11 AM
jdmmax's Avatar
ohhh ok
ohhhhh ok thats what i figured i have a lot of miles on my 99 and i driven it hard plenty of times before the mod. thats what i was kinda figureed it could be. hey thanks guys!!! oh well have any of you two heard anything about the level 10 tranny rebuild kits. alot of money to be spending with out any word on how well they work.
thanks guys
Old Feb 21, 2002 | 10:21 AM
Raf2kMax's Avatar
Re: ohhh ok
thanks guys
i think the complete rebuild at level 10 costs like 3 grand..i dunno if anyone on the org has done it yet. in my opinion..i dont think its worth it. the valve body mod is good though.
Old Feb 21, 2002 | 11:41 AM
jdmmax's Avatar
Re: Re: ohhh ok
i think they sell a kit for like 650-700 dollars and its just the internals for the tranny. its the rebuild kit i am interested in. the (3k tranny) is a tranny with the rebuild kit and a valve mod mod so you got to pay for the tranny, VBMod, Rebuild kit plus labor to putit toghether.
Old Apr 16, 2002 | 10:38 PM
BLacKMax69's Avatar
just had mine reinstalled today...if i didnt have heavwy chrome 17's i would spin....i dont know how much of a diff..im going g tecking and tell my results
Old Apr 17, 2002 | 12:11 AM
Cumalot's Avatar
Could be the tires. When I had my stock 15" rims with stock tires on, I could chirp second gear quite often. Now that I have more stickier tires on the stock 15s, I can't chirp second gear anymore. Although, Don did told me that my tranny might be in pretty bad shape because the VB core that I sent back to him had rust in it. Too expensive to have it check out, so I guess I have to live with for now.
Old Apr 17, 2002 | 07:46 AM
BLacKMax69's Avatar
i hope i ddint get that one???? when did u get yours????
Old Apr 17, 2002 | 10:49 AM
Cumalot's Avatar
I doubt it because I got it a long time ago.
Old Apr 17, 2002 | 12:23 PM
max'n out's Avatar
Re: Re: Re: ohhh ok
The kit from Level 10 is 700. The 3k is that kit installed, thats it. No vb mod, no tc upgrading in anyway. Also there clutchs modaswell be paper.
Find a good tranny shop and do some crazy custom stuff like me .
Old Apr 17, 2002 | 12:41 PM
1MAX2NV's Avatar
I can't either, maybe because I have 245/40/zr18. I do break them loose in 2nd if I hit the juice at 3000rpm.
Old Apr 18, 2002 | 09:57 AM
jdmmax's Avatar
Re: Re: Re: Re: ohhh ok
[QUOTE]Originally posted by max'n out
[/QUOTE
what did you have done to make your tranny stronger
Old Apr 18, 2002 | 10:20 AM
max'n out's Avatar
Re: Re: Re: Re: Re: ohhh ok
[QUOTE]Originally posted by jdmmax
[/QUOTE
I posted it in both forums but here is the list:
Upgraded and blueprinted transaxle for extreme duty application, which includes durability upgrades, balancing of internal components, and valve body modification.
Custom axle
Custom Transaxle housing
Heavy-duty differential
Torrington bearing set
Teflon Bushing kit
Kolene direct steel
Ceramic direct clutch pads
Kevlar Bands
Billet clutch drum (high Drum)
Race sleeves
Tapered roller bearings
Ring and Pinion Gear set
Case harden torque converter input hub and fluid balanced the converter
Hardened input shaft
A Custom form of Posi traction
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
As you can see, not just stronger but better in everyway.
Old Apr 18, 2002 | 10:32 AM
BSwithTF's Avatar
Re: Re: Re: Re: Re: Re: ohhh ok
Custom axle
Teflon Bushing kit
Kolene direct steel
Kevlar Bands
Race sleeves
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
Estimated cost for something like that?
Old Apr 18, 2002 | 10:52 AM
max'n out's Avatar
Re: Re: Re: Re: Re: Re: Re: ohhh ok
Considering it's one of a kind,theres no kit. It would depend on you going to my guy and saying I want exactly what he got, or finding a shop and asking them to do somthing similer, so the price would vary with the shop and state and so forth. But as for a doller figure just figure it's out of 99% of peoples price range.
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
