Scanned image of my dyno plot. It's crazy, look!
Old Feb 27, 2002 | 09:06 PM
emax02's Avatar
I finaly mastered the art of working a scanner tonight, pretty damn easy actually . Well heres the scan of my dyno plot. Now take a look at how my powerband just keeps on going! Every other dyno of the 3.5 VQ I have seen drops like a stone right before 6K rpm. Also take a look at how smooth my lines are compared to others. Take a look at Steves dyno here: http://www.frankencar.com/product_i/...o_after_lg.jpg , and compare it to mine. My car is smooth the hole way up and keeps on going. Tell me what you guy's think!
Sorry the pic is a little small, it's the best I could do.
Old Feb 27, 2002 | 09:17 PM
PhatGuy
Ya your car seems to have more useable power than any other 3.5 I've seen.
Old Feb 27, 2002 | 09:18 PM
emax02's Avatar
I had Nissan make mine special just for me
Old Feb 27, 2002 | 09:30 PM
freeze2k2's Avatar
Its the little 20 shot in the trunk.
Old Feb 27, 2002 | 09:32 PM
N1sMO's Avatar
STOP IT!!!! You are making me want to get a 2k2. Damnit, there's more power at 4.2k in your car than my car at 6k. Aaaaaahhhhhhhhhhhhhhh!!!! And even if I SC my car, I won't get useable power like this.
Old Feb 27, 2002 | 09:37 PM
emax02's Avatar
Just wait until I get some headers
Old Feb 27, 2002 | 09:39 PM
Blackgums100's Avatar
Oh yeah
The new 3.5 is a beast, someone mentioned that the Z car will have 300 ft.lbs of torque. I am very jealous.
Old Feb 27, 2002 | 09:41 PM
emax02's Avatar
Re: Oh yeah
The max has about 270-280 TQ stock so it's not that much more
Old Feb 27, 2002 | 10:21 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Old Feb 27, 2002 | 11:54 PM
AznWontonboy's Avatar
Originally posted by Y2KevSE
Im confused too
Old Feb 28, 2002 | 02:09 AM
02MaXiMa_GLE's Avatar
Let's find out... Try it!!!
G
Old Feb 28, 2002 | 06:23 AM
mattattax's Avatar
I'm really looking forward to getting some headers too. Let's all keep our eyes peeled. You have mad amounts of power, my goal is to get my auto where yours is right now but it's not likely I'll be able to get such great results. How much do you think headers'll run if Stillen comes out with'em?
Old Feb 28, 2002 | 07:07 AM
Frezny's Avatar
Re: Oh yeah
And there's word going around about the GT-R35 getting a VQ35DETT!!!! Now that would be SWEET!
Old Feb 28, 2002 | 08:06 AM
N1sMO's Avatar
Have you looked at the torque numbers? SC is only good for hp...
Old Feb 28, 2002 | 08:30 AM
Y2KevSE's Avatar
Is the torque curve as flat and as usable than this?
http://wwwcsif.cs.ucdavis.edu/~chin/.../dyno_sc_a.jpg
Old Feb 28, 2002 | 08:55 AM
nismo2020's Avatar
Needs non-Maxima Friends
isnt the cats right around the place that would be the "headers" ?
Old Feb 28, 2002 | 09:50 AM
N1sMO's Avatar
Holy ****... That *IS* pretty flat Makes me feel a lot better. What are the numbers b4 3k rpm? Under normal driving condition, my car rarely go above 3,000 rpm. That's usually my shift point.
Old Feb 28, 2002 | 10:05 AM
emax02's Avatar
The headers will also include a Y-Pipe.
Old Feb 28, 2002 | 10:09 AM
emax02's Avatar
$800ish probably.
N1sMO, below 3K a superchareged auto 2000 has a LOT less TQ. The SC does not kick in until atleast 3000 RPM. If you go with a real small pulley like Kev the power may start to kick in at around 2.5K RPMS.
Old Feb 28, 2002 | 10:11 AM
nismo2020's Avatar
how is the 3.5 exhaust system set-up. correct me if im wrong -exhaust manifold into two main cats on each side into dual pipes to a flex section then a small resanator then into a large resanator then muffler?
Old Feb 28, 2002 | 10:21 AM
emax02's Avatar
One manifold has the cat connected(one peice), the other manifold bolts onto a pre-cat which is part of the Y-Pipe. From there, there is the main cat, then the B-Pipe which has a resonator in it and then that goes into the muffler.
Old Feb 28, 2002 | 10:46 AM
Y2KevSE's Avatar
If you don't drive hard under 3K, then boost will not kick in.
$800ish probably.
2.5K? How about a little under 2K.
Old Feb 28, 2002 | 10:51 AM
emax02's Avatar
I was close The dwarf on my I30 was a sleep below 3K
How much TQ are you putting down at 2K RPM?
Old Feb 28, 2002 | 11:04 AM
SuDZ's Avatar
$800ish probably.
Wow. Not coming cheap huh.
SuDZ
Old Feb 28, 2002 | 11:16 AM
Y2KevSE's Avatar
I was close :-o The dwarf on my I30 was a sleep below 3K :-D
Don't know what the torque is because it'll downshift when you mash the pedal in 3rd at 2K.
Old Feb 28, 2002 | 11:27 AM
emax02's Avatar
SuDZ
They did'nt get the nick name $tealin for nothing
Old Feb 28, 2002 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
Re: Re: Re: Oh yeah
Originally posted by slammed95
You think "The max has about 270-280 TQ stock so it's not that much more." Nope, the '02 maxima has 246ft-lb. of torque. I saw it somewhere in the paperwork when I bought my car, but I can't remember at what RPM's it peaks.
What he figured was that you use the same driverain loss % as you did for the hp #'s, so therefore if he had 20 % drivetrain loss, he got 270 ft/lbs at the crank.............got it?
Old Feb 28, 2002 | 11:39 AM
emax02's Avatar
Re: Re: Re: Oh yeah
230 FWTQ is a hell of a lot more then 246 TQ at the crank . Nissan underated the TQ on these engines, get it?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
trsandrew
Oct 25, 2015 02:47 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Garrettz459
Sep 28, 2015 02:50 PM
