Breather Filter....(yes i friggen searched)
Old Mar 4, 2002 | 05:32 PM
Soon2BMaxed's Avatar
ok, after a search, i still have not found my answer. do u gain anything by putting on a breather filter? is it even worth it? or is it just for looks? please, someone elaborate with me here....
Trevor
Old Mar 4, 2002 | 05:38 PM
Vyrus's Avatar
Its just for looks or if your intake does not supply air to the location (which the stock one does). I have one and I guarentee there is absolutely no difference.
-Cyrus
Old Mar 4, 2002 | 06:06 PM
Supermachoman's Avatar
During normal compression stroke, a small amount of gases in the combustion chamber escapes past the piston. Approx 70% of these "blowby" gases are unburned fuel (HC) that can dilute and contaminate the engine oil, cause corrosion to critical parts, and contribute to sludge build up. At higher engine speeds, blowby gases increase crankcase pressure that can cause oil leakage from sealed engine surfaces. The purpose of the Positive Crankcase Ventilation (PCV) system is to remove these harmful gases from the crankcase before damage occurs and combine them with the engine's normal incoming air/fuel charge. Adding a crankcase breather filter simply allows these blowby gases to be released into the atmosphere, rather than rerouting them back into the manifold, where they can (as I mentioned above) dilute and contaminate the engine oil, cause corrosion to critical parts, and contribute to sludge build up. APC makes crankcase breathers that can be bought for $10-15 dollars.
Hope this clears thing up.
Old Mar 4, 2002 | 06:24 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
sooooooo.....it actually does work/serve a purpose??? interesting, where did you find this info??
Old Mar 4, 2002 | 07:22 PM
dwapenyi's Avatar
Is there a breather attached to each cylinder bank, or just one?? Maybe the other one is buried and you can't se it in pics
DW
Old Mar 4, 2002 | 07:24 PM
god that car is your sig is gourgeous(sp?)
thanks for clearing everything up guys!
Old Mar 4, 2002 | 08:15 PM
DA-MAX's Avatar
yup, sure is....and in a few years now that GM has come to their senses it will be in my driveway...hopefully!
Old Mar 4, 2002 | 09:57 PM
Nismo87SE's Avatar
Might as well install an oil catch can. This should reduce the oil vapors.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
bigdogsteve
Jan 31, 2018 04:18 PM
lrb6805
Sep 24, 2015 05:03 PM
