EGT Probe Install and Guage Questions
Old Mar 8, 2002 | 06:46 AM
ejj's Avatar
ejj
I had a few more questions about the EGT probe install...
I bought the probe with the clamp built onto it. Directions say to drill a 1/4" hole in the exhaust pipe and strap the probe into the hole. Has anyone installed this type or probe? Is there any exhaust leaks? Any recomendations.
I'll ask again...which part of the Y? Front or back? I've read that many people recommend the back, yet some use the front (MardiGras if I'm not mistaken).
Also..under normal driving what are your EGT's? Just so I know that everything is working properly.
Thanks!
Old Mar 8, 2002 | 08:27 AM
MardiGrasMax's Avatar
Re: EGT Probe Install and Guage Questions
I have an APEXi EGT gauge, it is different than yours. My temp probe is in the exhaust manifold. You will have lower readings than me because your probe will be in the y pipe. I peak at @805c with juicy boost and 780c with just boost.
Old Mar 8, 2002 | 10:10 AM
1MAX2NV's Avatar
I got the better probe that comes with a bung. Weld the bung on and stick the probe in. Two locking nuts to hold it in place. My installer did it at the y-pipe because he was lazy. It's on the rear bank of the Y-pipe.
Old Mar 8, 2002 | 11:14 AM
ejj's Avatar
ejj
What EGT's do you guys see with normal driving (not WOT or Peak)? Just highway cruising.
Old Mar 8, 2002 | 11:21 AM
Jeff92se's Avatar
I'm needing a caw
Re: Re: EGT Probe Install and Guage Questions
Which manifold? Does it matter that the probe is only taking readings from one side(I assume)?
Old Mar 8, 2002 | 11:29 AM
1MAX2NV's Avatar
It all depends on the load and speed I'm going. Cruizing 70mph..~1100F. All I know is going WOT around 100mph. I'm at 1300F. With nitrous I'm at 1400F. Anything higher than 1400F around 100mph. I'm running lean.
Old Mar 8, 2002 | 11:41 AM
ejj's Avatar
ejj
Originally posted by 1MAX2NV
It's all depends on the load and speed I'm going. Cruizing 70mph..~1100F. All I know is going WOT around 100mph. I'm at 1300F. With nitrous I'm at 1400F. Anything higher than 1400F around 100mph. I'm running lean.
Thanks Tony.
Old Mar 8, 2002 | 12:22 PM
Re: Re: Re: EGT Probe Install and Guage Questions
Well I'm sure it does matter, but I'm not launching a space shuttle here Cylinder 5 is the best place to mount.
Old Mar 8, 2002 | 12:23 PM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: EGT Probe Install and Guage Questions
haha. smartypants
Old Mar 8, 2002 | 12:29 PM
Chebosto's Avatar
RIceD OuT moDErAtor
T minus 10 seconds..
9..
8..
7..
6..
Main thruster ignite
5...
4..
3..
2..
And we have liftoff .. of the Space Shuttle Mardigras on a 7 day mission to break 400 fwhp..
Old Mar 8, 2002 | 12:36 PM
ejj's Avatar
ejj
Refresh my memory...that's the left side of the engine right (the half closest to the radiator)?
Old Mar 8, 2002 | 03:35 PM
mtrai760's Avatar
'Trynna' is not a word
Re: Re: Re: Re: Re: EGT Probe Install and Guage Questions
Correct.
Old Mar 8, 2002 | 06:20 PM
9..
8..
7..
6..
5...
4..
3..
2..
Shuttle MardiGras you are a go for water/alcahol injection and 2.87 pulley upgrade.
Old Mar 8, 2002 | 08:52 PM
Chebosto's Avatar
RIceD OuT moDErAtor
New Orleans. we have a problem.
Shuttle Mardigras, we have you on radar, but your engine is next to the moon.
PH98I30
Jan 9, 2025 08:08 AM
Cotozic
Jun 28, 2017 08:01 PM
95Maxi
Aug 25, 2015 08:01 PM
mikekay
Aug 10, 2015 12:52 PM
