rubbing compound question
Old Mar 9, 2002 | 11:52 AM
theblue's Avatar
I have never used rubbing compound and I have a question about a possible application for it
I have touched up a ton of little scrapes and chips on my hood with touchup paint, it looks a lot better. What if I use rubbing compound to try to smooth/blend the touched up areas into the rest of the paint. will this work???
Old Mar 9, 2002 | 12:46 PM
Frank Fontaine's Avatar
Re: rubbing compound question
Don't do it. Use a cleaner/wax instead. You'd be surprised how seemingly abrasive the stuff is, yet perfectly safe on clear coats. I've used Meguiar's and Mothers, both seem equally good.
Old Mar 9, 2002 | 01:47 PM
theblue's Avatar
Re: Re: rubbing compound question
interesting... but I don't think that wax will be strong enough to smooth out the bump created by the touchup paint's thickness
Old Mar 9, 2002 | 02:07 PM
theMax's Avatar
Re: Re: Re: rubbing compound question
try it, if you are blending paint then there is no clear coat to damage. If that does not work use a very fine grain sandpaper or steel wool.
Then get some clearcoat to cover your work.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
