5 speed tranny leak :(
Old Nov 20, 2000 | 07:33 AM
Dave B's Avatar
Not DAVEB the parts guy
Last night was toying around with my car and I was looking underneath when I noticed tranny fluid on the tranny housing. The leak is on the drivers side housing and it's leaking out where a rubber covered cable/line enters into the tranny. The cable/line is routed into the housing through a half-dollar shaped "cap" that has a small retangular gap at the bottom. This retangular gap is where the fluid is coming out, I think. The leak is very slow, but it still makes me a little worried. Does anyone know what this is? Access and replacement of this piece looks fairly simple.
Dave
Old Nov 20, 2000 | 09:00 AM
Nismo87SE's Avatar
Since the maxima is a hydrolic clutch
It is probably the speedo cable. I don't think the seal is hard to replace, after all when your speed sensor goes out. It will have to be replaced anyway.
Old Nov 20, 2000 | 10:32 AM
Dave B's Avatar
Ohhh..I think you're right. It probably is the speed sensor. There's a phillips head screw that holds the piece in place. What sucks is if I have to replace it, I'm gonna have to replace my fluid too!!! I just replaced the fluid 5 months ago!!!
Dave
Old Nov 20, 2000 | 10:41 AM
Jeff92se's Avatar
I'm needing a caw
Hmm on a 3-gen manual, the speed sensor is on top of the pass side cv joint area? But I think I know what you are reffering to. Just drain the tranny fluid into a clean container and then pour it back into the tranny. Take the sensor out and see if it's loose or if the seal area is damaged.
Dave
Old Nov 20, 2000 | 11:09 AM
Tmeyers's Avatar
No..heres what it is
Its the back up light switch/sensor..Mine was leaking also
last year (after I replace the fluid with RedLine) when my
97 5 sp was still under warranty...I had Nissan fix it.
It is not the speedo cable. They replaced it, drained out all
my new Redline oil and replaced with the OEM trans fluid.
I can scan in my Nissan paper work tonight if needed.
The PN's and description of the work is on the paperwork.
Hope this helps...
Tmeyers-Colorado
Old Nov 20, 2000 | 11:17 AM
Dave B's Avatar
Re: No..heres what it is
Hope this helps...
Tmeyers-Colorado
Thanks, if you could just give me the part numbers, unit costs, and what thier labor time was I'd greatly appreciate it. I'll have to take a look at the service manual.
Dave
Old Nov 20, 2000 | 02:11 PM
Johnny
I had the same problem
It's called the transmission switch, for the reversing lights. Mine was so subtle that you wouldn't even see the oil on the ground. It would cling to the casing since gear oil is 80W90. Took two tries for the dealer to fix it, and I took their word that it was done. Then I looked under the car 4 months later and sure enough it was still leaking.
The part number is 32005-17E11 and since mine was done under warranty I'm not sure how much it would cost.
Old Nov 20, 2000 | 05:09 PM
Tmeyers's Avatar
The PN is: 32005-17E11....SWITCH ASSY-POS
Description on paperwork
REVERSE LITE SWITCH IS LEAKING
REPLACED SWITCH
9 PINTS OF 75MTOIL 75 WT OIL
UNIT PRICE: COVERED UNDER WARRANTY
They also replaced my oil sending switch which was leaking.
(back behind the oil pan)
PN: 25240-89920 switch oil pressure
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
