Need Help with window regulator
Old Nov 20, 2000 | 09:59 AM
sTAE's Avatar
Can someone please tell me how to open up the door panel on a 3rd Gen Max?
Thanks!
Old Nov 20, 2000 | 08:57 PM
turbolaw99's Avatar
If I remember correctly, take off the door pull & the screw in the recessed inner door handle. The panel should lift up & then off. Good luck.
Old Nov 21, 2000 | 05:52 AM
sTAE's Avatar
Thanks! I'll try that.
Old Nov 21, 2000 | 11:27 AM
sTAE's Avatar
Well, I unscrewed the 2 screw underneath the door handle..but it still would budge. Are there more screws?
Old Nov 21, 2000 | 12:19 PM
DanNY's Avatar
Ad·min·is·tra·tor
woah there's a few more screws than that..
there's a plug at the top part of the door handle...screw in that..
lift up the door latch and there's a curved piece in there...lift that up..screws in that..
the handle should be out by now...there should be a screw in the bottm hole..unscrew that..
front part of the door there's 2 caps...unscrew both.
pull out the buttons and then lift door panels.
4 10mm nuts holding the regulator w/ the glass on it...good idea to undo the glass 1st.
Dan
Old Nov 16, 2007 | 03:05 PM
lehaska's Avatar
Window doesn't work - regulator/motor checked
I could use some help here. My window goes down fine but won't come up. I got a new regulator and after opening the door and testing the motor and the old regular. They work. The old regulator does the same thing though, it goes down but not up (it does with a little help). The motor spins back and forward when taken out of the regulator. I put it on the new regulator and it doesn't go up or down. My only guess now is that the motor is too weak??? oh and it's a 95 maxima gxe. I want to sell it but might be hard to get a good price with that problem.
Thanks.
Old Nov 17, 2007 | 07:55 AM
Pearl93VE's Avatar
I can has?
http://www.geocities.com/bracecraig/...regulator.html
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
