bmxsteve |
03-12-2002 07:25 PM |
Can someone help me with my transmission problem?? 95 5spd!!
Ok, Im going to do my best to describe my problem. I've got a feeling whatever it is, it's going to be expensive. When I put my car in reverse, giving the car moderate gas, and let the clutch out fully, the transmission will make a sound(like metal is dragging) and get stuck in reverse. No matter how hard you try to knock it out of reverse, the gear shifter is stuck. The only way it will pop out of reverse is if you have someone push the car forward and get it rolling. Then you can start pumping the clutch and knock it out. Now, if I put the car is reverse, but dont feed it too much gas, or dont let the clutch out completely, I'm ok. You can imagine that this a pain when going in reverse up hills, b/c the clutch has to be let out and fed a lot of gas, thus becoming stuck. Anyone has any ideas. What could it be?? Come on you transmission guys.(cough cough ex. eric, haha) THANKS a BUNCH!
