Tire Pressure...Please help
Originally posted by Eric L.
I run 37 front // 33 rear .
Seems to work fine for me. Any higher pressure and the ride is rough as hell.
Yeah, that's about what I set mine for. Different tires, but should be the same results.
with the plus one or plus two upgrade, you should run several psi higher than the fact. recommended specs. don't run what is on the tire; t hat's only a max rating.
36 to 38 should be fine.
I ran 39 psi on 245/40/17s on the Z
