Frankencar Updates
Frankencar Updates
Ok here's the latest happenings at frankencar. We are in the process of switching over to monster flow filters. www.monsterflow.com Also we are going to start offering custom colors at a $10 surcharge, we currently offer blue and silver at the regular pricing and will start to offer red, yellow and black for an additional $10 fee due to the decreased amount that we will have done and the additional fees from otu powdercoater, we are not making any money off that, it will cost 10 extra per unit for those colors and that's what we will charge you.
Re: Re: Frankencar Updates
Originally posted by soundmike
When's the flow coming?
Originally posted by theblue
how long for 4th gen pipe only to be ready?
Originally posted by dmbmaxima88
this time we reallly mean it, hopefully 2 weeks for the pipe only maybe even the full section.
The Monster Flow site is down - could you fill me in on what this is? I've been holding off on an intake because of all the reports of the oil from K&N's coating the MAF and then screwing up your performance. Is the MonsterFlow filter something that addresses this?
monster flow sell basically one filter as far as i know, so i assume it's the same one as monster flow. the monster flow filters is a foam filter with a velocity stack and turbulence reducers and they use a tactifitying agent that will not mess up MAF's (steve
) i don't expect a big increase on the dyno just smoother and maybe 1 hp but the maf thing is the biggest reason i switched.
Gotta get my clutch throwout bearing looked at first by Nissan though before I start adding mods (i've been dragging my feet) You know how Nissan is with mods
Originally posted by mattC
go back to bed brian
- 4th gen intakes are a bish to make... but me and steve will be working hard to get them ready in two weeks.
steve
That's just another one of those paraniod lead beleifs, like CAI sucking water and killing your motor. I got prarnoid myself, took off my CAI and checked my MAF. No problems at all. This was the first time I had actually looked at my MAF as well after 80K miles on a CAI with A K&N at the end. It re-oiled like 5 times.
DW
DW
Originally posted by SteVTEC
Cool! I need an intake! BAD!!!
They look slightly larger as far as i can tell.
Yep, seems like a larger filter would give you a slighter gain as showed by those dyno sheets done by ... hmm.. forgot (sorry whoever you are!)
Anyway, i'm getting mine (with MF filter) pretty soon, so we could easily gauge the difference in performance/sound and size of the filters once i get it installed.
Originally posted by mattattax
Are the flow filters any bigger than the K&N? everyone that sees my K&N says it's small, but whatever is best for performance is fine with me--and is there any kind of heat shield on the way for summer?
the flow filters are supposed to flow more air but an engine also can only require so much air. the main reason i'm doing this is because it's supposed to be smoother air and the tactifiying agent isn't damaging to MAF's. i imagine slightly less sound with this filter and we are actually working with monster flow to develop a heatshield made out of similiar material that thier filter cages are made of
Originally posted by dwapenyi
That's just another one of those paraniod lead beleifs, like CAI sucking water and killing your motor. I got prarnoid myself, took off my CAI and checked my MAF. No problems at all. This was the first time I had actually looked at my MAF as well after 80K miles on a CAI with A K&N at the end. It re-oiled like 5 times. DW
Thanks for the info
lol...I figured. I know how these forums go - filled with alarmist posts. I suppose over oiled K&N's could cause a problem, or not letting it dry out completely before putting it back on your car too.
Thanks for the info
Thanks for the info
-steve
Originally posted by Lime
MATTSY: "Wait til you guys hear about what Steve just told me in my voicemail...Frankencar is gonna have a busy night"
ohhh yer coming to CT to hand deliver my intake? That's sweet of you!
if you only knew. half of it was heatshields which should be soon for 5th gens and then 4th's but the other thing well
Originally posted by magnum
ok im once again confused... arent foam filters bad? why not just get a weapon r intake then? they use foam filters, and they seem to be much better quality.
I am a little bit confused too, so Steve what filter did you use with Franken Intake before?
Was it K&N? So you saying people who have K&N might have problems with MAF?
I though K&N was one of the best filters out there!?
I am still decide which intake to get.. I am so confused now
I want something that won't damage my car basically.
Thanks.
Thanks.
Thanks.
Thanks.
and 4thgen intakes. i just took a break from making them
if you only knew what me and my new best friend in california talked about on my lunch break.
You're killing me...
Originally posted by 190hpKiLLA
But you have to change the foam filter more often cause you know what happens when foam gets old? It separates and goes into your engine.
steve, will the k&n still be available as an option? cuz if i remember correctly...there was a thread awhile ago which lead to the conclusion that k&n(paper) is better than foam. This might be why most high end intakes come with them. And if i am not mistaken, u also need to oil the foam after u clean them, which might lead to the MAF issue too.
Bruce
charlie- we will still offer them as an option FOR NOW but we feel that the monster is a better unit overall then a k/n. place racing uses them now, are they high end? there must be a reason they are switching and why most BMW guys use foam.
-steve
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Mahmuth
Sep 25, 2015 10:08 AM
