Nissan brake pads....key value vs. OEM
Old Apr 17, 2002 | 04:59 PM
Albert's Avatar
I will be replacing my rear brake Bendix pads since
they squeel. They are not squeeling because Bendix
does not sell a "quiet" version for the rear.
I want to switch back to Nissan brand, but there
are two versions of that...key value and OEM.
They dealer wants $79 for the key value and $129
for OEM installed. Anyone knows what are the
difference?
Old Apr 17, 2002 | 05:07 PM
MAX2000JP's Avatar
Re: Nissan brake pads....key value vs. OEM
difference?
Why dont you check and see if Performance Friction makes a pad for your rears? Try www.autozone.com , I purchases front pads for 33 bucks there.
Old Apr 17, 2002 | 05:19 PM
MaximaRacer's Avatar
difference?
I can get you OEM pads for $50 shipped. Key Value for $40 shipped. Im my opinion oem ones are better caue I never had squealing with oem pads. email me at stanley@tssperformance.com
Old Apr 17, 2002 | 05:47 PM
mzmtg's Avatar
Minister of Silly Walks
I've had Key Value...they suck. They squeeled for the entire time they were on my car.
I have Performance Friction Carbon Metallic on the front now and OEM on the rear. It's a great combo.
I do know that Performance Friction does not make rear pads for our cars...
Old Apr 17, 2002 | 05:48 PM
Mike S.'s Avatar
Key Value is ****. Jeff92se had to replace his Key Value clutch really quick. He then got an OEM.
Mike S.
Old Apr 17, 2002 | 08:12 PM
EZ's Avatar
EZ
I first put in Axxis and they had problems with noise so I switched to OEM. The OEM's are wonderful. No noise whatsoever
Old Apr 17, 2002 | 10:29 PM
trinity000's Avatar
mzmtg i have the same front and rear pad setup... they don't make rear pads for our car i was going to get a set as i need some new rears!!!
question do yours dust like a **** i clean my rims and the next day they are black (still stock blade style rims grrr i hate them but need money for other things right now)
Old Apr 18, 2002 | 05:22 AM
Albert's Avatar
for the front pads, i use bendix iq. they
are great! i have no noise and better performance
than the OEM. the OEM would fade during stop
and go traffic. however, unlike the OEM, bendix
gives off a lot of dust.
for the rear, i'm getting massive squealing after
replacing a worn pair of OEM with bendix. so now
i'm going back to OEM. but for some strange reason
the dealer wants more $$$ to replace the rear than the front.
Old Apr 18, 2002 | 06:59 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Albert,
Make sure the exacerbated squealing isn't a result of a rear caliper "sticking" and forcing more pressure on pads that are thicker and thus *could* be the source of the noise.....
4th gen rear calipers seem to want to stick a lot.....
Old Apr 18, 2002 | 01:38 PM
Frank Fontaine's Avatar
Originally posted by bill99gxe
Albert,
I can only speak from my own experience and say that OEM's are very quiet. I forgot to reinstall 1/2 shims and still zero squeal from the fronts. I don't see any advantage with Key Value because you'd save maybe $11. Pads are about $45 over the web.
I'd try new shims in the back if those pads are fairly new because true, new OEM pads may not rid the squeal. But if there was no squeal before the new pads went in they may do the trick.
Old Apr 18, 2002 | 07:41 PM
Highlander's Avatar
I had Performance Frictions on my last car (Contour) and they were pretty good, very little dusting..
Anybody try Hawks yet? I'm going to be doing brakes in a few weeks after the next couple autocross events...
They sell them at Tirerack..
http://www.tirerack.com/brakes/resul...&autoYear=2000
vingodine
45
May 21, 2016 12:46 PM
03VQMAX
Sep 25, 2015 04:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
