Please help! My CEL came on.
Old Apr 18, 2002 | 02:57 PM
Bill Wattison's Avatar
A day or two after I installed my CAI, my 'service engine soon' light came on!
I've tried resetting the ECU by disconnecting the battery overnight, but after a day it came back on!
Does anyone know what could be wrong, and how to fix it?
I've tried reading the ECU code but my car is a '99 and that black ECU box is different than the other 4th gens'. It requires a small philips I think and it is in such an inaccessible location I don't think I can reach it w/out calling a mechanic to do it.
Anyways, if I just leave the CEL on for a few days, will it eventually go away as the ECU somehow becomes adjusted to the cold air?
My car is a '99 and has ~25k miles so I don't think the o2 sensors could be bad.
Ahh I am so frustated, especially since I spent all that time installing the CAI in the first place. It would be such a shame for me to have to return it to stock!
All help will be greatly appreciated!!!
Old Apr 18, 2002 | 05:29 PM
BRIGBOY's Avatar
Go over your install again,
Maybe the ambient air sensor, the MAF, a hose, something you forgot to hook back up?? The ECU is silver, and its right under the center dash, after you pull off the black plastic which hides it.
I wish I knew more about the 99s. But there is no distinction between the ECU's noted in my Haynes Manual, so you may be looking in the wrong spot.
Old Apr 18, 2002 | 06:02 PM
Re: Go over your install again,
I see the ECU unit, and it looks the same as the ECU writeups that I have read--but it says "Idle Adjuster" on it instead. Also, there is no screw inside for me to turn!
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
Marc2theMax
Sep 28, 2015 08:13 AM
