First knock sensor then EGR ceniniod now O2 sensor, whats next?
Old Apr 26, 2002 | 08:18 AM
nymjayjay's Avatar
I replaced the knock at about 100k along with the EGR control ceniniod now its showing I have a bad O2 sensor,. The one thats bad is the one right behind the intake manifold which goes all the way through the engine into the exhaust so I hear. Anyone know how much this censor usually goes for?
Jay
Old Apr 26, 2002 | 08:28 AM
NmexMAX's Avatar
dot dot dot ...
Should be between 60-120 dollars, depending on where you get it. It's really not that hard to get to, just get under the car and find it on the y-pipe, but getting it out may be the hardest part because it's probably been in there for quite a while.
Old Apr 26, 2002 | 08:32 AM
The_Bomb's Avatar
Re: First knock sensor then EGR ceniniod now O2 sensor, whats next?
Jay
How many miles do you have since you replaced your knock sensor??? All of those sensors going bad so close to eachother usually means they aren't going bad, but it is something else. I had 3 sensors go off at once and it turned out to be a leaking fuel injector. For your sake I hope it's not that. It's gonna cost a lot of $$$$ .
Adam
Old Apr 26, 2002 | 08:38 AM
nymjayjay's Avatar
Re: Re: First knock sensor then EGR ceniniod now O2 sensor, whats next?
Adam
I REALLY hope it isnt that.
p.s. I have 107k on my 96 max now
Old Apr 26, 2002 | 08:44 AM
NmexMAX's Avatar
dot dot dot ...
why did it cost so much? Was it because you replaced all the sensors proior to fiding out it wasn't the sensor? or is replacing the injector that costly? or, did thre leaking fuel mess other things up?
Old Apr 26, 2002 | 10:26 AM
The_Bomb's Avatar
The reason it costs so much is because of labor and parts. If it turns out to be a leaking injector they need to perfrom a "drip test" on each one to find out which one/ones it is. While three of the injectors are on the front and easitly accesible the other rquire the removal of th intake manifiold which takes time. Injectors aren't cheap. I found out about the injector from my car being on the diagnstic machine. I have not replaced any of the sensors since I was told they are not at fault. If you don't fix the leaking injedctor it will destroy your sensors and you catalytic converter over time.
The price that I was give was at least $500 dollars in labor, plus the price of each injector. That may not be a lot of money to someone who works full time, but to a poor colelge kid, it is a lot.
Hope this helps.
Adam
Old Apr 26, 2002 | 02:12 PM
NmexMAX's Avatar
dot dot dot ...
thanks, i just did the timing chain(s) on mine cost 1200, and im a college kid!! But I'll get throguh, lucky you got a 5spd from the begining, Im going to do the swap this summer when i get full time!! Just hope an injector doesn't go out on me.
Old Apr 26, 2002 | 05:26 PM
ny96max's Avatar
glad i had all 3 of mine changed
Ant
Old Apr 27, 2002 | 10:21 AM
eaglclon's Avatar
does the EGR valve have anything to do with idle?
Old Apr 27, 2002 | 10:52 AM
d_98SE's Avatar
thanks, i just did the timing chain(s) .
I thought that the t-chain was supposed to last the whole life of the car?
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
