Tightening rear shock piston nuts???
Old Apr 30, 2002 | 05:13 PM
Pappa Grande's Avatar
I did my suspension install (first time) myself this weekend.
Kyg/Axg and ground controls.
I’ll probably do a short write up soon:
Anyway – the biggest challenge I had was tightening the rear shock piston nuts. When I used a wrench the whole assembly would just spin around regardless of whether the car was dropped down or not.
What did I do wrong? In the end I had to use a pipe wrench to lock the damn thing down, and used another wrench by hand to tighten it. No way I could use a torque wrench with this method.
Can you guys tell me a better way to tighten the rear shock nuts?
Thanks.
PG.
Old Apr 30, 2002 | 05:39 PM
NotNew!!NewSN!!'s Avatar
i duno thats the way we do em, but we use air tools so it might be a lil different, butusually just put a wrench on it
Old Apr 30, 2002 | 06:27 PM
Chunger's Avatar
My other car is a Hybrid
I seriously hope you didn't you didn't use a visegrip or anything like that on the the shiny shock piston or the shock will be dead in no time.
You can usually loosen/tighten the center nut when the car is on the ground before/after you remove/install the struts/shocks.
Old Apr 30, 2002 | 06:29 PM
mb1's Avatar
mb1
I used a vice grip right on the top flat part, and tightened with an open end wrench.
Old Apr 30, 2002 | 07:15 PM
The_Bomb's Avatar
Ditto.
Old Apr 30, 2002 | 07:45 PM
why would that make it be dead in no time? im pritty certain we didnt have to do that on the agx's but had to do it when we were takin out the old shocks
Old Apr 30, 2002 | 09:45 PM
No, I didn't put any grip on the shiny part.
Vice grips is what I was missing - thanks guys.
Old Apr 30, 2002 | 11:32 PM
Chunger's Avatar
When you are taking out the old shocks, it doesn't matter cuz they are dead or nearly and you won't be using them again. It mars the surface that meets the seals below... destroying the seals as it goes up and down past them.
Old Apr 30, 2002 | 11:50 PM
KLOOGY's Avatar
L33t BMW Drivah
I did my own springs , and those bolts were a piece of CRAP !
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
6spd4dsc
Mar 4, 2016 05:19 PM
AcuraLegend
Sep 22, 2015 04:22 PM
