X drilled/Slotted rotors question
Old May 23, 2002 | 03:49 PM
MrBlank's Avatar
I just got my shipment from pmp designs. Do these rotors have to be resurfaced? and TWO can I change the rotors and leave the brakes?Also is there a write up of how to install/change someplace?or anything specific I need to know. Also a right up on how to install spark plugs would be appreciated also if anyone has the link.
Old May 23, 2002 | 04:19 PM
xHypex's Avatar
No don't resurface the rotors before you put them on. As far as I know you don't really want to resurface slotted rotors until you absolutely have to because it will wear down the slots.
It's ok to reuse pads, but take it easy the first few hundred miles so that the pad can seat on the rotor.
Here's info on brakes:
http://home.earthlink.net/~msue2/Wilwood.htm
Here's info on spark plugs
http://integra.vtec.net/geeser/megamax/60k_service.html
-hype
StygianMax's Avatar
Sorry, I don't have any "authoritative" answers for you.
I DO want to ask you how thickness measured across from one rotor disk to the other. (NOT the rotor diameter). I saw some Brembo rotors at a local shop the other day. Some disks looked much thicker than others so I guess they're less likely to warp.
Thx in advance!
Old May 23, 2002 | 05:37 PM
MaxRPM's Avatar
DO NOT REUSE your old pads, you'll most likely screw your rotors. It's ok to put new pads on old rotors, but not used pads on new rotors. Buy some new ones, even OEM ones, but use new pads.
Old May 23, 2002 | 08:21 PM
njmaxseltd's Avatar
Lightly sand the pads to expose new pad surface, then use the old pads just like they were new. (Only with a little less beef)
This sometimes stops annoying high squeals as well by exposing new, unglazed pad surface to mate to the rotor.
Old May 24, 2002 | 05:49 AM
sinewave's Avatar
Don't forget to clean off the new rotors with an aerosol brake cleaner. New rotors usually have a film of grease on them to prevent rust.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
