rim offset
Old Dec 3, 2000 | 09:00 AM
sleeper's Avatar
what rim off set will keep the wheels and tires in the wheel well? they can't both be the same because the front sticks out more than the back. i know this has been talked about before, but does anyone know what the offset would be for both front and rear wheels without using spacers, etc., thanks , Delos.
Old Dec 3, 2000 | 09:16 AM
Shingles's Avatar
The missing moderator
Well unless you plan on never rotating tires... then you cna't get different offset for front and rear. Also there is a reason why the rear track is small than the front, it's designed like that... you widen the track in the rear your car will be unstable, not to mention mad understeer.
-Shing
[Edited by Shingles on 12-03-2000 at 12:36 PM]
Old Dec 3, 2000 | 10:16 AM
Micah95GLE's Avatar
Yeah, use the same offset, front and rear.
Old Dec 3, 2000 | 10:37 AM
bullseye's Avatar
You using 17 x 8 wheels and 235/45/17 tires? Recommended offset on that is 35-40mm, according to the folks at O-Z Racing...
Old Dec 3, 2000 | 11:37 AM
FAST4EN's Avatar
Mine are Binno California 17x8" using 235/45/ZR17's. The offset is +40mm which keeps them right under the wheelwell's. The only thing that I've noticed is that they do rub when you turn the wheel all of the way (I.E. backing out of a parking spot, etc)
Old Dec 3, 2000 | 05:34 PM
sleeper's Avatar
[QUOTE]Originally posted by Shingles
[I]
-Shing
[Edited by sleeper on 12-03-2000 at 07:41 PM]
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
