Help!! I Need My Car To Live
OK so the other day a belt on my 87 maxima broke off. It was worn I should have replaced it long ago, I know. Right as it broke off my interior warning lights came on and stayed on, the sensor light and my check engine soon light etc... So not only did those light up, the next day my car started to stall out, and I actually had to jump it, along with that, the blinkers are dim, the windows and wipers are moving very slow, not to mention not being able to even turn my deck on. Obviously the battery is getting drained a large amount, could this snapped belt (which im not sure which one it is) be the only reason for this?
Re: Help!! I Need My Car To Live
I'd suggest you get a $29 battery and put it in and see what happens. If that also discharges then you need an alternator most likely.
Are you F***ing serious....you broke a belt and didn't replace it....those things are there for a reason and if they break something will not work....and since your altenator belt broke it stoped charging your battery hence the loss in electricity...did u think nothing was gonna happen when it broke off?
PS, if that broke, then I would venture to say your car is overdue for its servicing and other belts and hoses may be ready to go as well. What year is your Max? Dependant upon same, you may also have a timing belt, which if you allow that to go, you will ruin your engine. Get you regular 60K checkup/tune-up/belt replacements religiously and you'll be able to get 250k+ out of your Maxima like I did with my first one (which incidently would still be on the road had not an idiot totalled her.)
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
