my dust ring on my sub is coming off
Old Jun 19, 2002 | 11:20 PM
infinit30t's Avatar
one of my subs got banged up a little because my box is not bolted down and the ring on the outside is falling off, i figured silicone would be the best thing to use here but wanted to check first
Old Jun 20, 2002 | 12:03 AM
chinaonnitrous1's Avatar
Re: my dust ring on my sub is coming off
if thats the peice thats around the screwholes....silicone is fine..or glue...super glue..whatever..depending on the material..mine is actually plastic..or rubber...or..wood..so..just use the most suitable glue. Worse come worse..use that white elmers glue.
Old Jun 20, 2002 | 06:17 AM
Whitemax's Avatar
Disco Biscuit
Or buy a ring repair kit. Different places sell reconing supplies online...
Old Jun 20, 2002 | 06:37 AM
Coldboot-SE's Avatar
Foam Surround?
Are you refering to the foam surround that holds the cone in place
if so you can get repair surround at;
http://www.partsexpress.com/
http://www.newfoam.com
That foam can be repaired with silicone/RTV, but as it ages it becomes brittle and even if you don't work your speakers hard the surround will fail eventually.
Dave
Old Jun 20, 2002 | 04:16 PM
infinit30t's Avatar
no it is not not the foam it it is the little ring on the outside of the sub where you puts the screws in, i just didn't want to use something that would deteriorate the foam surround, and you say super glue won't do this
Maxie40
Sep 14, 2015 11:28 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Violator
Sep 9, 2015 10:14 AM
videomano
Sep 8, 2015 03:28 PM
lux97Max
Sep 4, 2015 05:42 PM
