Enrichment/Fast Idle Not Working on '87
The enrichment/fast idle on my 87 isn't working on cold start. It requires constant throttle to keep it running and has a miss until it warms up. Any ideas? Is there a way to get ECM codes find the problem? The check engine light is not on.
Re: Enrichment/Fast Idle Not Working on '87
Originally posted by Edge The enrichment/fast idle on my 87 isn't working on cold start. It requires constant throttle to keep it running and has a miss until it warms up. Any ideas? Is there a way to get ECM codes find the problem? The check engine light is not on. Thanks
It is the air regulator. Then try running a mode III test to see if anything else is bad. I've had the problem before too and it was the air regulator.
The senor light on the dash is on, but the cold start problem started well before this light came on, so I don't think it is releated.
Lilchikcadee
May 1, 2019 08:49 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
