Too much Redline Water Wetter?
Old Jul 2, 2002 | 02:36 PM
SunMax's Avatar
Hi all,
I bought a bottle of Redline Water Wetter a few months ago and finally got a chance to flush my radiator today. I pour the whole bottle in before I read the instruction on the bottle which says I only need to put in ~8 ozs for my '97 SE
My question is, will it do any harms? Should I flush it out and get another bottle?
Thanks!
Old Jul 2, 2002 | 05:18 PM
TurDz's Avatar
I really doubt you have to do that. You'll be fine. Oh yeah, be sure to watch your coolant reservoir...after a flush the level will get lower due to a few air bubbles and such.
Old Jul 2, 2002 | 05:33 PM
maxedout95's Avatar
Re: Too much Redline Water Wetter?
How much did you py for it ?
Old Jul 2, 2002 | 05:44 PM
Frank Fontaine's Avatar
Originally posted by SunMax
Hi all,
Thanks!
You're correct, you should only put the recommended amount. When I used to live in the cold some people would make the mistake of running 100% antifreeze, and no matter how much anyone told them otherwise they insisted it offered the greatest cold weather protection. Obvioulsy they flunked chemistry--though 50/50 is usually good enough to what, -34, you can go up to 70% antifreeze and 30% water for maximum cold weather protection. Beyond 70% reduces the benefits of antifreeze.
Old Jul 2, 2002 | 05:54 PM
SunMax's Avatar
Re: Re: Too much Redline Water Wetter?
So you think the extra 4ozs of Water Wetter will be bad for my radiator? If not, then what kind of harm can it be done?
Old Jul 2, 2002 | 06:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
leave in it..you'll be fine.
Old Jul 2, 2002 | 06:28 PM
speedtrip's Avatar
Hi all,
Thanks!
I would not worry about it to much if you still added a 50/50 mixture of water and coolant. I added a whole bottle of redline water wetter last year and have had zero problems. Occasionally in my area we see 8 F to 15 F as lows in the winter time. Redline recommends to use the whole bottle for a 12 quart system and we have a 9 quart system.
I run a 50/50 mixture of coolant and redline water wetter in my motorcycle. I store it out in a shed during the winter and it has not frozen yet. Unless you live in an area that requires regular use of an electric engine heater using to much water wetter will not be an issue for you.
Old Jul 2, 2002 | 08:13 PM
iwannabmw's Avatar
I found some in southern NH for $6.99.
Old Jul 2, 2002 | 08:29 PM
PATRICK94SE's Avatar
I paid $6.99. Poured the whole bottle in.
Running 80%water/20%Antifreeze
Old Jul 2, 2002 | 09:02 PM
BEJAY1's Avatar
Conecarver
How cold does it get in RI? Any problems running 80% water?
P.S. An extra 4oz of H20wetr isn't gonna hurt our 9qt system
Old Jul 2, 2002 | 09:07 PM
Well that is a May-October Mix. I will probably bump it up to 40% antifreeze for the winter.
Old Jul 2, 2002 | 09:27 PM
BEJAY1's Avatar
Conecarver
Ah. That's about what I run too. Never thought about running 2 setups...
Old Jul 2, 2002 | 09:30 PM
SunMax's Avatar
I paid $5. It was on sale at Pep Boys a few months ago. Normally I don't think they have it onsale though.
Old Jul 3, 2002 | 07:48 AM
johnny2kgle's Avatar
I believe the bottle says that the maximum water percentage is 70%. I am currently running approx. 70% with no problems.
Old Jul 3, 2002 | 08:50 AM
iwannabmw's Avatar
Which bottle, the water wetter or the anti-freeze. The water wetter can be run with a 100% water concentration for maximum cooling efficiency.
Edit: The Water Wetter can be run with 100% water and it won't hurt the system, but it still will freeze if your temps. drop below freezing.
Old Jul 4, 2002 | 12:43 PM
deadrx7conv's Avatar
Read the back of the antifreeze bottle!
Redline waterwetter will not damage anything. So, don't worry about it.
It will get slushy in the cold RI weather. If you garage your car, it isn't a problem. Parking it in a cold lot at work for 8 hours is. I froze a radiator on the highway because of windchill.
Just run 50:50 water/antifreeze. Takes all the thinking out of it. But first, pour in the waterwetter/purpleice/towcool/whatever and then top it off with the 50:50. I have used the waterwetter(whole bottle) for years and never had any problems. Plus, I usually run a little more engine timing and do not have pinging issues with 87 octane. And, 50:50 is good enough for 90% of the weather anywhere in the country.
And make sure you are using distilled water. The use of more water% reduces the amount of corrosion protection. Tap water will add to this corrosion issue. For those of you who do not use distilled water, stick with the 50:50.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
