Gauging Interest: A32 Maxima Front/Lower Strut Braces by GTFabrications
Old Jul 17, 2003 | 01:59 PM
TurDz's Avatar
http://gtfabrications.com/maxima/barsindex.htm
I just want to get a feel for how many people would be interested for the strut braces in the link above. Personally, I'm very interested in the lower strut brace. It connects the control arms and I've never seen anything like it.
A quote from a rep from GTFabrications:
"The lower arm bar ties in both A-ARMs substantially reducing flex during hard cornering. For cars with a weak chassis or bigger chassis this would increase the overall rigidity. In combination with a good strut tower bar it would help the car handle to a point where you can actually feel your suspension getting a work out. Since it also works your suspension a lot harder so you would have to turn down the valving on the suspension and or raise the spring rate. The car that we had made it for is using TEINs super street coil over set up. (These are new and would be available soon as well.)"
If there's enough interest, then I'll be able to start a group deal on the bars. Thanks!
Old Jul 17, 2003 | 02:01 PM
TurDz's Avatar
FSTB:
Old Jul 17, 2003 | 02:03 PM
TurDz's Avatar
Front Lower Brace
Old Jul 17, 2003 | 02:35 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Totally interested for both!
The design of the lower bar is similar in concept with the ones companies make for the S2000s, RSXs, etc. I rode in an S2000 before and after a Spoon Sports x brace was installed and you can feel the increased rigidity gained by the brace.
Is it made out of steel or aluminum?
Also I would like to pick up to save on shipping since I'm local. If there is enough interest can you work out a cash pick-up price with them for local members. Thanks.
Old Jul 17, 2003 | 02:46 PM
Chunger's Avatar
My other car is a Hybrid
Any ideas on the pricing? Can we NOT get red?
I'm interested in the lower strut brace.
Old Jul 18, 2003 | 01:17 AM
Nismo's Avatar
that lower A arm brace looks like it will do some major scraping for some of us. interested in hearing the prices of both pieces though.
Old Jul 18, 2003 | 03:15 AM
TurDz's Avatar
Yeah I've thought about scraping too. I guess it's just a trade off..
The price for both is $345 on their website...but I'm not sure about the group deal price. I just need to get more responses and see if it's worth doing a group deal.
Old Jul 18, 2003 | 03:16 AM
TurDz's Avatar
I think they can easily work out a black or silver powercoating of some sort.
Old Jul 18, 2003 | 04:04 AM
nubiannupe's Avatar
OG Maxima.org Member
Man, I'd tear that front lower brace the flock off!
nubiannupe's Avatar
nubiannupe's Avatar
Man, I'd tear that front lower brace right the flock off!
Old Jul 18, 2003 | 04:09 AM
nubiannupe's Avatar
Old Jul 18, 2003 | 05:58 AM
infinitiblast's Avatar
Posting for emphasis I guess. Looks decent....wonder if it would help with wheel hop?
Old Jul 18, 2003 | 08:24 AM
Requin6's Avatar
interested in the lower only.
--Paul
Old Jul 18, 2003 | 09:32 AM
ny96max's Avatar
that lower one looks to be atleast 2" below the scrape bar under the car... i dunno about that
Ant
Old Jul 18, 2003 | 10:01 AM
SpeedCrazie's Avatar
Interested in lower as well. Would this eliminate the need to do the SFC? Its funny cause I was just looking at these last night.
JP
Old Jul 18, 2003 | 10:03 AM
Also, not to get off the subject, are they saying that the Tein SS Coilovers will soon be avaliable??? Hmm.....$
Old Jul 18, 2003 | 10:13 AM
MaxPerformanceSE's Avatar
Interested in the lower brace only.
Old Jul 18, 2003 | 10:32 AM
teejnut's Avatar
Interested in the lower. Looks like it decreases the ground clearance by a lot though. How's the install? Simple bolt on I presume?
Old Jul 18, 2003 | 10:35 AM
Jeff92se's Avatar
I'm needing a caw
Looks nice: Questions though.
1) Install. You have to use longer bolts?
2) What does it do to ground clearance?
3) So if you have to do some tranny/exhaust work, you have to remove those long control arm bolts to take the brace out??
Old Jul 19, 2003 | 06:54 AM
arthur glazier's Avatar
lowwer brace
I called and talked to them last week and he did not know if it would fit 2k max. Will it fit with aftermarket y pipes? But I am interested in just lowwer if it will fit
Old Jul 19, 2003 | 11:03 AM
Mishmosh's Avatar
Interested in the lower only. Preferrably black!
Old Jul 19, 2003 | 07:13 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
That looks interesting. I would also like the lower one as well and if it came in bronze color like the addco rsb.
Old Jul 20, 2003 | 03:35 PM
Smokin' X-press's Avatar
I may be interested in the lower one too. But I'd like to know
1. Would it clear the cattman ypipe
2. Are there are any other sort of modifications required to make it fit.
3. clearance
4. How would this work in combination with a FSTB and RSB. Would it make the chassis too still in combination with the RSB
Old Jul 21, 2003 | 10:29 AM
Canuck's Avatar
Old Jul 22, 2003 | 10:25 AM
Luquire's Avatar
I have a warpspeed y-pipe and I have eibachs. Am i going to have trouble with ghround clearnce or y-pipe clearance
Old Jul 22, 2003 | 06:27 PM
the paragon's Avatar
interested in lower
Old Jul 22, 2003 | 11:09 PM
96shogunmax's Avatar
intested in lower, although I would rip it off w/my sprints...
Old Jul 23, 2003 | 05:00 AM
Confused's Avatar
Permanent Maxima.org Resident
how much does the lower piece weigh?
Old Jul 23, 2003 | 11:42 AM
TurDz's Avatar
I'll post that information up soon. Also, I will ask about clearance issues.
Thanks for all of the interest.
Old Jul 24, 2003 | 04:41 PM
Anachronism's Avatar
Since it is in between the front wheels I think ground clearance should not be a huge problem. The place I scrape the most with my SFCs is going up driveways and speed bumps. In both these instances it looks like the lower bar would lift over the obstical (sp?) with the front tires.
Old Jul 24, 2003 | 10:08 PM
krbga's Avatar
My only concern is the stress on the Tie Bars.
Old Jul 25, 2003 | 02:49 AM
carnal_c30's Avatar
Former Sponsor
hmmm how much is the price for these?
oh well... i cant go for these... i scrape enough as is
Old Jul 25, 2003 | 04:58 PM
mitch33x's Avatar
I might be interested in the lower bar
Old Jul 28, 2003 | 07:50 AM
VMaximus02's Avatar
Can you ask the manufacture and see if the lower tie bar will fit on the A33 chassis (2000-2003)? If so, I might be interested.
Old Jul 29, 2003 | 11:47 AM
Flava_24/7's Avatar
Boosted Panda
if clearence is not an issue and fits with y pipe im in.
Old Jul 29, 2003 | 12:14 PM
mitch33x's Avatar
any updates?
Old Jul 30, 2003 | 11:24 AM
mitch33x's Avatar
Everybody who is interested, vote!
http://forums.maxima.org/showthread.php?threadid=236718
Old Jul 30, 2003 | 03:46 PM
TurDz's Avatar
Thanks Mitch for the reference link. I just posted a little FAQ on the newer thread so go check it out!
Old Sep 8, 2003 | 06:51 AM
doublea's Avatar
Hey, I'm interested in the lower part, depending on price and how low the clearance to the ground is, my max is already lowered and the road are crap over here so I dont want to scrape the road on daily bases.
Let me know.
AA
MaxStock
Aug 14, 2015 09:59 PM
acw
Aug 13, 2015 12:50 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
MaxStock
Aug 8, 2015 01:18 AM
laparka66
Aug 6, 2015 09:36 AM
