Calipers! Maxima and 300zx Front and Rear Fully Remanufactured!
Old Nov 1, 2004 | 10:25 PM
derrick's Avatar
Hi guys,
After all of the brake work I've been doing I came into contact with a great source for calipers. I know a lot of you have been doing 300zx brake upgrades using various rotors and brackets, and here is your chance to get the calipers you want!
Or maybe you don't care much for brake upgrades, but your stock calipers are terrible and you want some nice freshly rebuilt ones to replace them with.
Calipers available (300zx fronts and rears come with brand new brake hardware, maxima fronts and rears do not have brake hardware):
300zx 30mm aluminum front pair = $250
300zx 26mm aluminum front pair = $250
300zx Aluminum rear pair = $200
Maxima Front or Rear Pair = $150
Prices do not include shipping. If you are interested simply email or pm me with which caliper(s) you would like and include your shipping zip code and I will get back to you with a quote. Thank you for looking!
Old Nov 2, 2004 | 09:19 AM
ny96max's Avatar
set of stock rears shipped to 11731. ny96maxse@aol.com
thanks,
Ant
Old Nov 2, 2004 | 10:19 AM
Zack342's Avatar
how much for a set of 300ZX 30MM calipers shipped to Zip 02368
Old Nov 2, 2004 | 07:28 PM
derrick's Avatar
If you want a quote please email or pm me with the info, otherwise I can't keep track of the quotes. Thanks!
Old Nov 4, 2004 | 03:34 AM
derrick's Avatar
Thank you to those who ordered so far! GD will be open until the end of this month
Old Nov 4, 2004 | 03:55 PM
ny96max's Avatar
ill know for sure by Sat if i need them from you. Thanks for the quick reply!
Ant
Old Nov 4, 2004 | 10:30 PM
derrick's Avatar
No problem Ant, just let me know.
For those of you interested, remember to pm me with your car year and model, front or rear calipers, max or z calipers, and shipping zip code. Be sure to be specific so I know what i'm quoting you on. and remember, pm or email only, I won't reply to posts on this thread for quotes. Thanks!
Old Nov 4, 2004 | 10:42 PM
krismax's Avatar
Father of the 00 VI
What is the weight of a front and rear 300zx caliper.
Old Nov 4, 2004 | 11:50 PM
PearlRalizinG2k's Avatar
sorry but i'm a retard when it comes to brakes, but i know for d@mn sure my stock ones sucks. but 30mm are those the regular Z32 non turbo? or the Z32tt??
Old Nov 5, 2004 | 09:01 AM
derrick's Avatar
krismax: front z's are roughly 12 lb / pair and rear z's are roughly 10 lb / pair
pearlralizing2k: http://www.princeton.edu/~asad/zbrakes/ that link should help you learn more about z calipers
Old Nov 5, 2004 | 09:52 PM
wow derrick that is a good learning link!! thankz a great deal.
Old Nov 6, 2004 | 12:33 AM
krismax's Avatar
Father of the 00 VI
What is the 300zx rotors thickness and how does it compare to our thickness. If i buy these calipers i want to put them on my stock rotors.
Old Nov 6, 2004 | 04:24 AM
derrick's Avatar
Thanks krismax, it helped me a lot too when i first started learning about these things.
Old Dec 10, 2004 | 10:10 AM
derrick's Avatar
hey kris: did I ever get back to you on it? the calipers can't be used with oem max rotors, except for maybe the 6th gen rotor upgrade with z calipers that matt93se is offering.
Old Dec 13, 2004 | 08:42 PM
Deac's Avatar
Set of rear Calipers for the 5th Gen.
derrick,
I live in NY 11553. I have slotted and dimpled rear rotos already but I think they are a direct stock replacement in terms of size. Can I still get the calipers from you or do I need different rotors? If so what size will I need. Thanx...
Deac
Old Dec 13, 2004 | 09:00 PM
Matt93SE's Avatar
STFU n00b!
You do not want to use the Z32 rear calipers on an otherwise stock brake system.... helloooooo tail happy!
If you want to do the Z32 rear brakes, you can see what's involved on my website...
http://www.mattblehm.com/brakes.html
Old Dec 14, 2004 | 09:02 AM
Deac's Avatar
I have all ss lines already and the wilwood big brake kit of the fronts. I just wanted to even thing out a bit in the rear brakes. Again even my rear rotor are slotted and dimpled. Will the rear 300zx calipers work for me?
Deac
Old Dec 14, 2004 | 09:11 AM
Matt93SE's Avatar
STFU n00b!
They will, but you need to do more than just bolt on the calipers. the factory rotors are about 3/8" too thin, and the wrong diameter.. and the Z32 calipers don't have a parking brake built in- which is required by law.
thus, I've created a rear brake kit using the proper parts. see the link in my post above for more info on it.
Old Dec 14, 2004 | 11:26 AM
derrick's Avatar
yeah matt's right about the rears, his kit will get everything you need especially that e brake. i believe he offers everything minus the calipers, which i can supply you with deac.
Old Dec 15, 2004 | 10:26 AM
Andrey3000's Avatar
Wich calipers do you use in your front big brakes kit setup for 97 max, 300zx 30mm aluminum, or 300zx 26mm aluminum?
Thnx
Old Dec 20, 2004 | 10:45 AM
derrick's Avatar
hey andre, most people use the 30mm upgrades.
Old Dec 21, 2004 | 02:11 PM
alpimax99's Avatar
interested in pair of rears
factory replacements wanted for 02777
Old Dec 21, 2004 | 02:20 PM
derrick's Avatar
hey alpimax, email or pm me with that info and let me know if it's front or rear calipers you want, i'll get that quote out to you after i get the email or pm, thanks!
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
RealityCheck
Aug 5, 2015 06:18 AM
