Brembo Brake Rotors - Crossdrilled, Slotted, & Original Equipment - HUGE DISCOUNTS!!
I'm back to do more business with you (my 3rd time, I should have gone with new rotors instead of turning, they are warped now). Anyway...
How much for a pair of 96 Maxima front Brembo blanks shipped to 98021?
Thanks,
David
Thanks,
David
I assume you mean "there are no FRONT Brembo Slotted Rotors"; Yeah, Brembo only makes Front OE style rotors for the 2002+ Maxima's currently. But you can get Powerslot Slotted Rotors for the front and rear.
I meant just what I said, I checked the website and did not see the brembo power slot rotors for the FRONT for the 2002 maxima. I was asking if they are not in stock or what because I know I had the in 2006.
There is no such thing as a "Brembo Power Slot" Rotor. Brembo and Power Slot are two completely different brands. All Brembo makes for the 2002 Maxima are OE Replacement rotors. If you see anything else available elsewhere, then they are just modified Brembo OE Rotors. Many places will drill or slot them themselves and mark up the price. Those rotors are usually the worst quality.
So I'd imagine this deal only applies to brembo rotors and not the power slot rotors, is that correct?
Entirely my mistake, which is an easy detail to overlook. My last experience with the POWER SLOT front with PBR deluxe plus on the 2002 maxima was great. Once the pads heat up, the pedal feel was pretty solid.
Thanks,
Mike
Order placed #41863, front power slot PAIR and PBR deluxe plus front pad set for the 2002 maxima. At least I can get the rear brembo power slot rotors.
Hi...I would like to get a price please on Brembo blanks, Hawk HPS pads, for all 4 wheels for my 2000 Max. I live in Toronto, Canada and would like the prices and shipping listed individually for comparison please.
Regards!
Regards!
I've ordered from you guys before and I'm back for more. May I please have a quote for 4 (all around) Brembo blanks shipped to 33615? This is for a 1997 GLE. Are these the zinc coated ones?
Brembo Sport Slotted or Drilled Rotors are made to OEM specs and have a zinc plating along with the respective cross-drilled or slotted design. These cost noticeably more than the OE Rotors.
