3RD. ROUND H.I.D. PLUG & PLAY KITS $245 SHIPPED ALL K, 6000k, 7000k, 9000k, 12000k GD
Originally Posted by bashboy2000
just installed my h3 xenon storms there doa 12 v going into the balast balast is hooked up to the ignitors ignitors to the bulbs i waited ten minutes and still nothing came on there is no continuity on the bulbs but i dont think there would be because there like florescent with no filiment. I HAVE NO HEADLIGHTS NOW WHAT CAN I DO and i had to drill into and cut wires in my brand new halo 2 angel eye projectors to do it
Regards,
Originally Posted by 97MaximaSE97
Yeah I'm unfortunately having the same problem with my 9004 kit not lighting up at all!!! Is there any solution to this?
Regards
just emailed the pics
REgards,
have you checked your email
Originally Posted by maximo-SE
Hey maximabest, Im looking for a Bluish/White HID Conversion Kit for my 2007 Camry LE. You have something that will fit that car? get back to me. thanks
*also whats the warranty on these kits?
Install Issue
I just had the H4 6000K kit installed and whenever I turn my high beams on the lights just shut off. No kind of a high beam effect at all. I'm assuming this is not the correct behavior of the hi/low kits right? Any suggestions as to why this is happening? Thanks in advance.
hey maximabest, i bought a kit from you a while ago. I got a 9004 6000k kit, but i was wondering if you sell the 9006 harness that connects from the ballasts to the the headlight ???? i'm going to get a 06 camry and i believe it uses 9006 headlight bulbs. i have everything else i need except the harness that connects from the ballast to the headlight socket... thank you.
Originally Posted by maximabest
hey whats up, just one question, your camry will be the new one? cause the new one has H11 bulbs on the projectors headlight. Just check and we can help you to make the swap.
awesome !! well, my camry is the 2006 version, so its not the newest model. i believe new ones are 2007's. yea, so i think it uses 9006 bulbs... but anyways, i'm very happy to hear that i can swap ! do you want me to send back the 9004 harnesses so you can send me 9006 after ?? thanks !!!!!!!!
send me an email to: info@xenon-shop.com you are missing some connections there, you need to check the diode and also the connection of the main harness. Send me the email and i will send you the pics for the installation.
i do appoligize i am very sorry and thank you for the response i hope to hear back from you soon
hehehe but fine, check your email for reply.Regards,
thank you i recieved it this time sent you a response did what you said and have sent another response hope to hear back soon
