ICHIBA USA Aluminum Wheel Spacers 5MM & 15MM Free Shipping!
ICHIBA USA Aluminum Hubcentric Wheel Spacers
WWW.ICHIBAUSA.COM
Free Shipping Within 48 States (US)
Note: Please mention you are from "Maxima.org Special" in checkout page, we will adjust free shipping for you.
5MM Aluminum Wheel Spacers $59 (Sold As One Pair 2pcs With 10pcs Longer Studs)
15MM Aluminum Wheel Spacers $99 (Sold As One Pair 2pcs With 10pcs Longer Studs)
New Update:
20MM, 25MM & 10MM is coming by NOV 2006!
WWW.ICHIBAUSA.COM
New Update:
i'm about to drop my car on tein s-tech on stock rims & tire size (225/50/17)
i don't know much about spacers, but i don't think the 5mm would make that much of a difference would it?
if i get the 10mm do you think the rear would rub with the fender
thinking about 5mm front and 10mm for rear
any comments from other members?
Here is how you can measure the size and the size converter.
The widest point of your tire and wheel combination is usually the outside diameter of the tire sidewall. Using a ruler with the straight edge flush with the face of the tire, measure the gap between the outer face of the tire to the inside lip of the fender as shown in the diagram. This will determine the thickness of the spacer you will need.
5MM = 0.197 INCH
10MM = 0.393 INCH
15MM = 0.590 INCH
20MM = 0.787 INCH
25MM = 0.983 INCH
5MM = 0.197 INCH
10MM = 0.393 INCH
15MM = 0.590 INCH
20MM = 0.787 INCH
25MM = 0.983 INCH
Originally Posted by roro
just want to make sure i have my facts straight. using a 5mm spacer on a +40 offset wheel will make the effective offset +35... is that correct? or is it the other way around...
Originally Posted by soundmike
Quick Q. Are these hub-centric?
p.s. sorry, posting remotely, can't see pics.
5MM is not due to your OEM hub is good enough to hold your rims.
Originally Posted by vq356sp
Please update when 10mm are available for the Max and pricing please
BTW do the 10mm require the longer studs?
Custom Package?
Can you offer me longer studs then that currently offered in a package. (custom package)
Lets say I order the 5mm spacer set, can I get 60mm long studs? (longer then most other kits)
And lets say I want to order the 15mm kit. Can I get 70 mm long stud?
ill get some , i just dont know what size spacers i got , i think they are 25 but i wonna make sure, main thing i need is hub centric
which studs r u giving with them??? nismo 60 mm ones??????
Originally Posted by resurrectedmax
can i order a set of longer studs only for a 20mm spacer?
Originally Posted by LatinMax
You know that if you are lowered the rear end shifts to the right at rest.
Eiback springs with a 1.5" drop will shift the rear end to the right 10mm.
Originally Posted by ichibausa
You can drop your car and finish up the alignment before put in the wheel spacers.
when you drop a 5th gen maxima, the rear beam shifts a little bit (in some cases)
My car does not have this problem.
Keep this deal going, I'm down for a set of spacers soon after I get my car fixed.
Originally Posted by MaxBoost925
he's referring to our suspension, it doesn't have to do with normal 4-wheel alignments.
Originally Posted by bohead
Still curious about shipping to Canada. Are you willing? if so, how much extra would it cost me?
we will send the item as a gift so might help you skip the duty fee as well.
okie .. $20 shipping to Canada sounds good?
I tried ordering off your website, but Canada isn't an option for destination. Plus I found your same product on Ebay for the same price. So I'll just order it from you off of Ebay.
Local customers can pick up from our local dealers.
Here is the link that you can find out the nearest one. http://www.ichibausa.com/dealers.html
Yes.
Do you have the 10mm in stock already? I know that the 5mm are not hubcentric, are the 10mm ones?
Originally Posted by xoomer.com
Even on the 5mm???. How hard is it to replace those. How much should I expect to pay at the shop to get them swapped?
You can do it yourself, it won't be very hard to swap the studs.
5MM is not hubcentric due to your original hub is good enough.
10MM is coming very very soon.
