JD-lightings 50watts HID $145 shipped!
Old Oct 12, 2007 | 11:19 AM
AuToMaX_95's Avatar
removed
Old Oct 12, 2007 | 11:25 AM
AuToMaX_95's Avatar
removed
Old Oct 12, 2007 | 11:41 AM
AuToMaX_95's Avatar
removed
Old Oct 12, 2007 | 04:09 PM
wyche89's Avatar
i don't understand why the bulbs come in different wattages.. what are the advantages/disadvantages to having the 50 watt vs. the 35 watt bulbs? from the picture there doesn't seem to be much difference
Old Oct 12, 2007 | 06:25 PM
AuToMaX_95's Avatar
If you look at the lum chart, 50 watts’s output are much much brighter it the sense of visibility. Meaning if you get 6000k you are not going to lose any visibility, is like having factory hid 4000k visibility output but 6000ks look.. ( sorry if is confusing) If you search under google, there is much literature under 50 watts HID advantage.
As I mention before 50 watts hid price range from $165-$285. So the price we are offering are ridiculously low.
Is hard to show the actual output from a picture but that’s the best we can do.. Even though you can still tell that 50 watts on the left is brighter than the 35 watts on the right.
p.m replied
Regards
jason
Old Oct 15, 2007 | 02:25 PM
jsmithsole's Avatar
*moderator*
PM sent...
Old Oct 16, 2007 | 12:38 AM
AuToMaX_95's Avatar
J
p.m replied!
thanks
jason
Old Oct 17, 2007 | 02:51 PM
cerumo's Avatar
hid
Jason,
just in case it's for 97 stock maxima housings (9004) 5000k. single beam. Thanks!
Norman.
Old Oct 17, 2007 | 02:54 PM
AuToMaX_95's Avatar
got it!
thanks norman
Regards
jason
Old Oct 18, 2007 | 07:20 PM
maxximaa's Avatar
where does the kit get the power from? stock harness or battery?
PRICING:
Single beam kit:
We have the following kit in 50 watts for $145 shipped!
h1, h3, h3c( mini), h4, h4h, h7, h10, h11, h13, 9003, 9004, 9006, 9007, 9008.
4500k, 5000k, 6000k, 8000k, 10000k only
$145 shipped to Canada? mark as gift and lower item value?
Old Oct 18, 2007 | 08:07 PM
AuToMaX_95's Avatar
the kit its power from from headlight harness.. the hid only requires 12v of power just like any other hid 35watts on the market, only difference is the bulb/ballast
shipping to Canada will be $15 extra.
i just the post a bit, totally forgot about the Canadians =)
thanks
jason
Old Oct 18, 2007 | 09:24 PM
allmotorVQ35's Avatar
Can we get some more pics of 50 vs 35 watts? And to be more specific some color shots of 6k and 8k? I know it's difficult to set up cause it takes a lot of time but it'll help some of us make our decisions easier.
Old Oct 18, 2007 | 10:11 PM
AuToMaX_95's Avatar
honestly the picture can't really do its justice just like the current picture i have up there.
From a PICTURE is really hard to tell.
if you want to see the color chart difference you can just goto www.tech1hid.com this kit and techone kit has the same amount of output.
And yes it is a pain in the *** to set up the comparison pictures, the above pictures are just for general referrence
Old Oct 19, 2007 | 10:48 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
You gotta a pm
Old Oct 19, 2007 | 11:48 AM
AuToMaX_95's Avatar
p.m replied!
thanks
jason
Old Oct 19, 2007 | 11:27 PM
96blkonblkse's Avatar
Ill help the seller. I recently went from a 35W 6000K kit to a 42Watt 6000K kit, and i can tell you i noticed a big difference in light output. the 50watt would definately make a huge diff especially for those considering 8000K + where light output is dramatically reduced.
The only disadvantage i can think of is, now glare is even more of an issue, but if you have 2 touch up paint bottles like the ones you buy from the dealership you can make your own glare sheild very easily!
Old Oct 20, 2007 | 03:12 AM
soundmike's Avatar
Very sound, Mike
Would i need to replace wiring harnesses to use the 50w kit on a 2k2 Maxima? I'm concerned about possibly melting 'em with the higher draw.
Thanks.
Old Oct 20, 2007 | 11:43 AM
AuToMaX_95's Avatar
Everything the 50watts kit comes with thats all you need to install, there are nothing else you need or need to upgrade.
Regards
jason
Old Oct 20, 2007 | 11:44 AM
AuToMaX_95's Avatar
thx
Old Oct 20, 2007 | 01:07 PM
ßaller's Avatar
...Or if you have a true hid retro with projectors, that would be even better. I am going to also see if my friend with an 07 camry with halogen projectors would buy one, since its got a nice cutoff, I don't think any glare would be a problem.
Payment sent for 50watt D2S Kit.
- ßaller
Old Oct 20, 2007 | 06:28 PM
MrDicks95SE's Avatar
Offset Is Everything.
why no 3000k 50W? if you have em id be down for getting a set of those.
Old Oct 20, 2007 | 10:41 PM
AuToMaX_95's Avatar
3000k output is already as is maximum capacity the 50 watts will be the same. We do have 50 watts 3000k kit but they are the same as 35watts
Old Oct 21, 2007 | 09:00 AM
IlyaK's Avatar
The Golden One
PM Sent.
Old Oct 21, 2007 | 11:38 AM
AuToMaX_95's Avatar
All p.m replied!
jason
Old Oct 21, 2007 | 09:59 PM
MaximaPower's Avatar
do u sell just the bulbs?
I'm looking for 35W D2S bi-xenon 6000k bulbs for replacing my stock bulbs
also, my stock fog lights are H1 55W...does that mean I would need ur 50W HID kit for my fogs?
Old Oct 22, 2007 | 05:10 PM
Maxima 504's Avatar
Do you know if this is still plug an play for a 1999 Caddy Eldorado.
Old Oct 22, 2007 | 05:31 PM
cprx7's Avatar
nm answered above
Old Oct 22, 2007 | 08:42 PM
AuToMaX_95's Avatar
D2S bulbs are $85 a pair shipped
Stock fog light are halogen You can get either 35watts or 50 watts hid, it wouldn't have any effect with your stock current.
the Caddy i am not sure, some do some don't
Regards
jason
Old Oct 26, 2007 | 02:54 PM
Maxima 504's Avatar
BUMP..............................
Old Oct 26, 2007 | 03:46 PM
gcxandrew's Avatar
has anyone installed this yet? do you get high beamed becasue it seems really bright
Old Oct 26, 2007 | 06:42 PM
AuToMaX_95's Avatar
on the caddy, I can't guarantee but i am 90% sure that you will have no problem with the install as the way the kit is.
Regards
jason
p.s the picture is showed abvoe with low beam only
Old Nov 2, 2007 | 09:40 AM
AuToMaX_95's Avatar
All order has been shipped! please take some pictures!
Regards
jason
Old Nov 3, 2007 | 06:27 PM
YGPM.
Just sent a PM on a 8k kit. I'll have pictures comparing it to the 35w 8k bulb once the kit gets here for all those unsure of the difference in brightness.
Old Nov 3, 2007 | 09:16 PM
eK9aT10pSi's Avatar
sorry if this is a repeated q but so i understand...
i have an 04 max with oem hid's. i want to upgrade them to 6k. how big is the difference from the 35w kit to the 50w kit?
and would it be plug n play to the oem harness?
and also, i wanted to convert my stock fogs to hid ones. ive read its best to go with the h3c mini due to fitiment issues. suggestions? would they be yellow? kinda like the is300 fogs?
thanks again.
Old Nov 4, 2007 | 01:52 AM
We didn't have any issues using a standard H3 for the fogs on our 3.5SE.
Old Nov 4, 2007 | 04:39 PM
n3985's Avatar
大陆弟弟
Can you get the 50W slim ballasts? Or does this brand not sell them?
Old Nov 5, 2007 | 09:26 AM
AuToMaX_95's Avatar
We do have slim digital 50 watts ballast but i don't recommend it. We test 2 kits of the slim digital ballast. 1 is on a R6 another is on a 02 m3. Both kit fail at about the same time which is 6-10 month. Now if you really want it i can sell it to you, and the kit will still cover under 1 year warranty, however is a hassle for you to deal with the RMA.
the LM chart is on top, you can tell the difference between 35w and 50w kit from that.
Yes all kit are plug and play nothing extra needed
H3 is fine, h3c will blow after 6-10 months of useage, yes we have warranties cover things liek that but is just a hassle for you keep having to send them back and forth. H3 will fit fine, yellow is 3000k, when order make sure you mention 3000k.
Old Nov 5, 2007 | 11:05 AM
Can I get a tracking number?
Old Nov 5, 2007 | 11:51 AM
AuToMaX_95's Avatar
p.m send
thanks
jason
Old Nov 9, 2007 | 08:28 AM
Luquire's Avatar
I have been looking for a kit for my wife. She drives a 2007 Santa Fe and it takes H7 bulbs for the low beam. I see you selling all sorts of kits over the past year. What is the advantage/disadvantages of this kit versus the others? All your kits seem to stay pretty much in the same price range give or take 10 bucks. I am really looking for reliability with this product so the wife doesn't complain. I would like the 50 watt but i need to make sure her harnesses can handle it.
Also forgot to ask....Are you still selling Axxis Ultimates.
