HID Reverse Kit - $75 shipped
Aug 20, 2011 | 05:43 AM
In what is arguably the strangest thing we've ever had come through... An HID reverse light kit.
Applications:
Universal
-(2) 15W HID Ballasts
-(2) 6000k HID Bulbs
-Extension Wires
-(2) T10 Adapter-to-Ballast Harness (Fused)
--(2) 3157 / 3156 Adapters (Wiring Necessary)
--(2) 1156 Adapters (Wiring Necessary)
Frequently Asked Questions
Q1) Will this melt my housing?
A1) Honestly can't answer that. Under normal operations, you should not have a problem.
But it is a much brighter bulb, so if you do leave your reverse lights on for extended periods of time (let's say to the tune of 30 minutes), you might cook something.
Q2) Do I need a relay harness?
A2) Nope. We've tested these on a few different vehicles, and none of them required a separate wiring harness for the reverse lights.
Q3) Can I use a 35w or 50w ballast?
A3) We have tested a 35w ballast with these bulbs and they fired up just fine. No long term testing was performed though.
A 35w HID ballast will not work if you decide to use it as a reverse light though.
Q4) Can I use this as a Daytime Running Light (DRL)?
A4) As long as it's not a high beam bulb that doubles as a DRL light. For instance...
High beams on a 2011 Honda Pilot are the DRL lights. This will NOT work.
DRL lights on a Hummer H2 or Chevrolet Camaro, then yes they will work.
Q5) Will these work as driving lights?
A5) Wouldn't see why not, but I the 15w ballasts are probably not going to be any brighter than the stock headlights. Which brings us back to Q3 when running 35w HID ballasts.
Q6) Will this affect my factory wiring?
A6) It should not. If anything happens, the fuse on the harness should blow out first.
Q7) Are these waterproof?
A7) Yes, but I would still suggest using dielectric grease on all connections.
And the question everyone really wants to know; do I have pictures installed? No bueno! >_<
Unfortunately I haven't had an excuse to really do this.
I have 3 of these right now, with 4 more coming in. Best thing to do is email me at hanh(at)3bspec.com
Aug 20, 2011 | 06:13 AM
may buy one of these for my dark no light driveway
Aug 20, 2011 | 10:22 AM
lmao...the mod for when all other mods have been completed! there is officially no part of the maxima that cant be modified!
Aug 20, 2011 | 07:22 PM
Ive thought about rigging up some hids in my reverse lights and running them to a switch. And blinding these rednecks in their big *** lifted trucks with purple HID's running high beam all the time.
Aug 20, 2011 | 08:21 PM
how long does it take to get full brigtness? Aftermarket headlight HID takes a good 5-10 seconds to get full brights with 35W ballast.
Aug 20, 2011 | 08:39 PM
Quote: lmao...the mod for when all other mods have been completed! there is officially no part of the maxima that cant be modified!
Can we use that as a tag line? "For when you've run out of stupid stuff to do; HID Reverse lights!"
Aug 25, 2011 | 08:35 AM
Quote: how long does it take to get full brigtness? Aftermarket headlight HID takes a good 5-10 seconds to get full brights with 35W ballast.
Completely missed this question.
About 10-seconds. Even when they're not warmed up yet, they're still brighter than just about any LED bulb I've come across.
Aug 25, 2011 | 10:48 AM
Quote: Ive thought about rigging up some hids in my reverse lights and running them to a switch. And blinding these rednecks in their big *** lifted trucks with purple HID's running high beam all the time.
HAHAHA...totally know what you mean!
Aug 25, 2011 | 12:41 PM
Do these take long to warm up?
Aug 25, 2011 | 01:07 PM
i want to get a pair of cheap $15-20 find-at-walmart fogs, mount em on my rear deck aimed towards the driver behind me, so when these nj/ny drivers want to make that poor decision of tailgating me, etc, they shall be greeted with 55-65w of light...in the eyes! but the accidents that may happen afterward is still a thought on my mind im trying to get out so i can do this guilt free lmao
Aug 25, 2011 | 03:35 PM
Quote: Do these take long to warm up?
About 10-seconds.
Quote: i want to get a pair of cheap $15-20 find-at-walmart fogs, mount em on my rear deck aimed towards the driver behind me, so when these nj/ny drivers want to make that poor decision of tailgating me, etc, they shall be greeted with 55-65w of light...in the eyes! but the accidents that may happen afterward is still a thought on my mind im trying to get out so i can do this guilt free lmao
They have to prove guilt first. The trick is, blind'em long enough where they won't have time to write down the plate, but not so long they it's obvious you're messing with the natives
Aug 26, 2011 | 06:59 PM
Do you have any pics of them not installed?
Aug 27, 2011 | 05:05 AM
Quote: Do you have any pics of them not installed?
Let me see...
Aug 27, 2011 | 09:21 AM
Quote: They have to prove guilt first. The trick is, blind'em long enough where they won't have time to write down the plate, but not so long they it's obvious you're messing with the natives
i doubt they would have time to adjust their eyes to read my plate for a few! lol. no i mean my guilt feeling by intentionally blinding someone risking them to crash. but then again, they sit on my ***, they deserve it.
Sep 2, 2011 | 03:49 PM
Sold out for the moment. Should see a few more sets come in, in a couple weeks.
Sep 3, 2011 | 08:22 PM
How come a 35w ballast won't work as reverse ballast? I know you said you tested them and fired up fine, but then again you said it won't work.
Sep 3, 2011 | 08:25 PM
i think it is probably due to the heat that running the bulbs at 35 watts will cause. Most reverse light areas in taillights are rather small, allowing for heat to build up easily and not dissipate. Also many 35watt aftermarket ballasts take a while to warm up. Up to a minute or more in some cases, which would make their use as a reverse light a waste of time(would have to wait a while to be able to see anything.
Sep 3, 2011 | 08:54 PM
Quote: i think it is probably due to the heat that running the bulbs at 35 watts will cause. Most reverse light areas in taillights are rather small, allowing for heat to build up easily and not dissipate. Also many 35watt aftermarket ballasts take a while to warm up. Up to a minute or more in some cases, which would make their use as a reverse light a waste of time(would have to wait a while to be able to see anything.
I wanted to retrofit OEM ballast which warms up at a blink of an eye. I mean, it's not like I drive in reverse.
Sep 6, 2011 | 08:01 AM
Question: Im still wanting to do this but where would I mount the ballasts? On the 4th gen the reverse lights are on the trunk lid
Sep 6, 2011 | 01:22 PM
I like it! On a serious note, do you have HID for the fogs? h3 bulbs and ballast?
Quote: Can we use that as a tag line? "For when you've run out of stupid stuff to do; HID Reverse lights!"
Sep 8, 2011 | 09:50 AM
Quote: Question: Im still wanting to do this but where would I mount the ballasts? On the 4th gen the reverse lights are on the trunk lid
id extend the harness for the bulbs and run them behind the carpeted paneling by the jack maybe around the antenna
Sep 8, 2011 | 12:13 PM
Quote: id extend the harness for the bulbs and run them behind the carpeted paneling by the jack maybe around the antenna
but then you would have visible wires running from the tails to that area
Sep 8, 2011 | 05:20 PM
Down for a set when they come in, these new 5% tints are killing me, haven't had them on again since 09', my eyes are getting old.
Sep 9, 2011 | 06:54 AM
Can I buy just the bulbs? And in 5000k?
Sep 9, 2011 | 10:42 AM
Quote: Can I buy just the bulbs? And in 5000k?
im thinking 5000 is nicer, does that get rid of all the coughricecough blue?
and yeah hid reverse kit ... HIDs are officially a fad (or trend)
Sep 9, 2011 | 10:47 AM
I've had one for a while, but did it for a specific reason. It's still totally unnecessary, but sick non the less.
Sep 10, 2011 | 07:10 AM
Quote: but then you would have visible wires running from the tails to that area
no i mean behind the carpeting ran with the factory harness for the taillights
Sep 13, 2011 | 10:01 AM
Got 5 more of these that came in.
Sep 17, 2011 | 05:49 AM
Quote: How come a 35w ballast won't work as reverse ballast? I know you said you tested them and fired up fine, but then again you said it won't work.
The reverse wiring can't put out enough wire to fire a 35w ballasts. I've seen guys try to run a 35w ballasts like this before and the HID's just blink.
Quote: I like it! On a serious note, do you have HID for the fogs? h3 bulbs and ballast?
Yes, just use the coupon code: Maxima-50, when ordering from 3bspec.com
Only able to get these in 6000k. I suppose I could sell just the bulbs.
Sep 21, 2011 | 12:59 PM
Is this what you mean?
http://www.youtube.com/watch?NR=1&v=VK345aRzOC8
Sep 21, 2011 | 01:03 PM
yes, only with a regular set of cheap fogs that i would mount on my rear deck.
Oct 6, 2011 | 08:18 AM
I'd like to see a picture of these installed.
Oct 6, 2011 | 08:27 AM
Let me know how much for just bulbs please.
Oct 24, 2011 | 12:09 PM
Still selling these set-ups? Do you have a set in stock for a 97-99 rear or are they universal 95-96 and 97-99?
Oct 24, 2011 | 12:32 PM
Quote: Let me know how much for just bulbs please.
meao
Nov 16, 2011 | 09:28 PM
Quote: Still selling these set-ups? Do you have a set in stock for a 97-99 rear or are they universal 95-96 and 97-99?
Ready to buy, waiting for reply...............
Dec 16, 2011 | 08:43 PM
Do you still have more of these? PM me
Mar 15, 2012 | 08:29 PM
Mar 16, 2012 | 04:34 AM
They would, but with the heat from the bulbs you run the risk of melting.l
