AMSOIL Synthetic Brake Fluid - DOT 3 & DOT 4
Old Mar 1, 2013 | 05:17 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
AMSOIL Synthetic DOT3 and DOT4 Racing Brake fluids provide superior performance in auto/light-truck, high-performance, racing and powersports applications. These premiere quality brake fluids feature pure base stocks and robust additives that resist boil-off and the effects of water contamination much more effectively than conventional brake fluids do. These fluids provide exceptional High-temperature stability, yet flow easily at low temperatures.
CONTAMINATION
Water contaminates the brake system by seeping through microscopic pores in flexible brake lines and seals and through the reservoir fill cap when opened. Once inside, it quickly works to corrode brake parts, lines and seals, leading to eventual system failure. AMSOIL Synthetic Brake Fluids keep water in suspension, slowing its corroding effects. They lubricate and protect intricate braking components despite the inevitable water absorption associated with braking systems, delivering long-lasting performance.
BOIL-OFF
The extreme pressure and high heat common to braking can push conventional brake fluid beyond its boiling point, causing it to vaporize, or “boil-off.” Even more problematic, water contamination can drop the boiling point of conventional fluid below safe standards, accelerating the rate at which it boils off. This leads to a spongy or unresponsive feeling in the brake pedal. In contrast, the unique chemistry behind AMSOIL Synthetic Brake Fluids increase their boiling point temperatures well beyond Department of Transportation (DOT) standards even when contaminated with 3 percent water. They maintain a stable viscosity over a wide temperature range and flow easily at the high pressures generated in today's automotive brake systems to deliver consistent, safe braking. AMSOIL Series 600 DOT 4 Synthetic Racing Brake Fluid features a wet equilibrium reflux boiling point (Wet ERBP) nearly 100°F higher than the DOT minimum, making it ideal for high-performance cars, motorcycles and vehicles used for towing.
20-yr Nissan owner, >10-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for customized quote
Wholesale Pricing Available!
Old Mar 6, 2013 | 03:17 PM
My deals don't expire. Wholesale pricing available on premiere quality AMSOIL synthetic lubricants; complete line of filters by AMSOIL, Wix and Mann; NGK ignition products; Mothers; Trico and more.
Old Mar 17, 2013 | 06:49 AM
It's important to change brake fluid. Water contaminates brake systems by seeping through microscopic pores in flexible brake lines and seals and through the reservoir fill cap when opened. Once inside, it quickly works to corrode brake parts, lines and seals, leading to eventual system failure.
In addition, AMSOIL Synthetic Brake fluids have a higher boiling point than conventional brake fluids do and they resist "boil-off" significantly better. The unique chemistry behind AMSOIL Synthetic Brake Fluids increase their boiling point temperatures well beyond Department of Transportation (DOT) standards even when contaminated with 3 percent water. They maintain a stable viscosity over a wide temperature range and flow easily at the high pressures generated in today's automotive brake systems to deliver consistent, safe braking. AMSOIL Series 600 DOT 4 Synthetic Racing Brake Fluid features a wet equilibrium reflux boiling point (Wet ERBP) nearly 100°F higher than the DOT minimum, making it ideal for high-performance cars, motorcycles and vehicles used for towing.
Old Mar 18, 2013 | 05:41 PM
Old Mar 23, 2013 | 02:43 PM
This brake fluid outperforms petroleum fluids by a wide margin and offers outstanding, long term protection to braking systems. I am confident you will be very pleased with this product. Pls send PM for pricing.
Old Apr 7, 2013 | 11:08 AM
Old Jun 8, 2013 | 07:41 AM
Old Jun 15, 2013 | 03:13 PM
Old Jun 29, 2013 | 06:32 AM
Old Jul 20, 2013 | 06:17 PM
CONTAMINATION
BOIL-OFF
Old Jul 27, 2013 | 05:45 AM
This is a premiere-quality synthetic brake fluid...outstanding product!
Wholesale Pricing Available! Pls send PM for customized quote or e-mail direct at lonestarlubes@gmail.com
Old Aug 3, 2013 | 06:20 AM
Old Aug 25, 2013 | 02:05 PM
Old Aug 31, 2013 | 06:18 AM
Old Sep 7, 2013 | 03:50 PM
Available at retail from my website at www.lubedealer.com/lonestarlubes OR, send PM or e-mail direct at lonestarlubes@gmail.com for quote. Wholesale pricing available
Old Sep 14, 2013 | 03:10 PM
CONTAMINATION
BOIL-OFF
20-yr Nissan owner, >12-yr org member, AMSOIL Certified Dealer, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM for customized quote
Old Sep 22, 2013 | 06:04 AM
Outstanding fluid for street or track. Available at retail from my website at www.lubedealer.com/lonestarlubes OR, send PM or e-mail direct at lonestarlubes@gmail.com for quote. Wholesale pricing available!
Old Oct 5, 2013 | 06:27 AM
knight_yyz
Nov 1, 2015 01:34 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
