Fish tailing at high speed...
Old Mar 18, 2003 | 07:14 PM
bugz_nz's Avatar
Hey, my A32/I30 is fishtailing at high speeds and it's beginning to freak me out. Anybody at this problem before or know what it could be?
Old Mar 18, 2003 | 09:08 PM
SYCEFIRO's Avatar
Re: Fish tailing at high speed...
Check Alignment, suspension, and your wheel balance. It could also be that your tires have uneven wear (Due to bad alignment or bad suspension).
Just my $.02
Old Mar 18, 2003 | 09:29 PM
I30tMikeD's Avatar
I don't know, that sound crazy. I would at least stop dirving at high speed till you find out what up.
Old Mar 19, 2003 | 03:10 AM
SLC I30t's Avatar
I agree with Sycefiro.
If you had uneven wear on your tires and then rotated them to the rear you will have a lateral lean on the rear of the car. if its a sudden pull while driving, I would check the rear suspensin and make sure all the bolts are tight and the bearings to see if there is play in them. a good way to check this is barely lift the car off the ground with a jack so the tire is a few cm off the ground and give the top of the wheel a good tug. the whole car should wiggle a little, if just the wheel wiggles then you might have a bad bearing.
be safe.
oh or the geometry of the car might be off, you can have the frame measured and adjusted.
Old Mar 21, 2003 | 02:06 PM
bugz_nz's Avatar
Took the ride down to Nissan to get it checked out, apparently my rear-right shock is leaking so that's gonna be a bummer. I'm hoping that's all it is...
Old Mar 21, 2003 | 02:47 PM
Asian_N02's Avatar
Maybe now is a good time to upgrade the suspension???
Old Mar 29, 2003 | 05:44 PM
JSpecMax's Avatar
I dont think the shock would make you experience such fishtailing, unless by high speeds you are talking 100+mph. If you are experiencing this on the highway at moderate speeds, like 65-75mph, then the shock isnt the issue. Let me know what happenes...
Old Apr 3, 2003 | 09:09 PM
bugz_nz's Avatar
Yeah, high speeds down the highway, it would be fine and then suddenly it would feel like the back was pulling away from the front in a sideways direction. Very scary, found myself driving like a granny down the road. My right rear shock came up as leaky when they checked it. Have since had it replaced and all seems to be fine although I haven't had a chance to open it up fully yet.
Don't be tempting me with suspension upgrades.... I'm a poor little worker elf.
Old Jan 27, 2006 | 05:15 PM
wolfpack_5150's Avatar
Apple Pie Monster
check rsb? I dunno just throwing ideas out there, and no im not lost I stumbled into the i30/35 section to lookup an issue for a friend... Hi to all the 30-35 owners.
Old Jan 27, 2006 | 06:22 PM
I30tMikeD's Avatar
A few years too late
Old Jan 28, 2006 | 10:29 PM
HomerMAC's Avatar
Donating i30 Owner
we dotn want ur kind.. hehe.. j/k why would u think we would jump on u.. were the nicer orgers over here in teh infiniti section.. = )
and yea.. the rsb was a great idea... the rsb is knows to cause fishtiling..
Old Jan 29, 2006 | 03:51 AM
AlexI30's Avatar
I know my car shakes at high speed (About 70 mph it starts to be felt)
After Changing a tie-rod and ball-joint because i was told they wer no good, i found out that its just the stupid front right tire that has a big dent it the rim that is causing the shaking (althought the tie-rod and ball joint were in need of a change anyways)... sorry i know it doesnt have to do with fishtailing, although i do feel my car is slightly fore unstable than usual. Sorry for hogging your thread, just expressing frunstration for lost $$$$ (After a night without sleep and way too much energy on my hands)
Old Jan 29, 2006 | 04:01 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Wow, 3 year old thread. Hope his car is fixed by now
Old Jan 30, 2006 | 10:04 AM
1sentra(VQ)'s Avatar
lol raised from the dead.
Old Feb 1, 2006 | 07:53 AM
Tim96I30t's Avatar
I thought digging up the old ones was my job,lol
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
