Updated pics of clear corners
Old Jun 9, 2003 | 03:13 PM
Kal's Avatar
Kal
I hope this helps some you that had questions, and for any more information feel free to email me at skppatel@aol.com or instant message me at skppatel.
Old Jun 9, 2003 | 08:58 PM
infinitiman96's Avatar
Re: Updated pics of clear corners
Looks AWSOME man
Old Jun 9, 2003 | 09:02 PM
ratledge's Avatar
Stupid newby question: where'd you get 'em? I've driving an '02 I35...
Old Jun 9, 2003 | 09:05 PM
Kal's Avatar
Kal
I didnt buy them. I did them myself. I took the headlamps off my car, heated it enough to seperate the lense and housing and broke the yellow plastic inside off.
Old Jun 10, 2003 | 04:34 AM
kingofsorrow's Avatar
DROOL!DROOL!DROOL!DROOL!DROOL!DROOL!DROOL!DROOL!DR OOL!DROOL!DROOL!DROOL!DROOL!DROOL!DROOL!DROOL!DROO L!DROOL!DROOL!DROOL!DROOL!DROOL!
am i making myself clear?
Old Jun 10, 2003 | 09:42 AM
I30tMikeD's Avatar
OK, not to rain on anyones parade, but when I cleared out the corners on my I30 I thought it looked really wierd with out anything in it's place. The exposed bulb does not look right.
Old Jun 10, 2003 | 01:47 PM
Kal's Avatar
Kal
Mike i totally agree with you. Thats mainly why i still have my regular bulb in there, cause a colored one will stick out. The way the bulb is positioned looks kind of wierd also. Looking at it a couple feet away you cant see the clear bulb, where a colored one would stick out. I hear there are silver bulbs but when lit are colored. I might look into those or do what someone else did which was put a light coat of silver paint on it. We'll see what goes on.
Old Jun 10, 2003 | 10:13 PM
I30tMikeD's Avatar
Although it still looks bette than the orange
Old Jun 11, 2003 | 05:34 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
There are silver colored bulbs that light up orange. I have them in my tails (1156) because I cleared out the tails and it looks funny with the orange bulbs. I'm looking for 1157 that have the same silver color for the front corners.
Old Jun 15, 2003 | 08:35 PM
ratledge's Avatar
Well, there we go again! };^) Where'd you get the silver bulbs that light up amber? (mine's an '02, so I might now use the same bulb # for front and/or rear) Do you do the same as 'kalbundy' - just take them off and use heat to separate the yellow part of the lense from the cover? (for the rear lamps)
Can anyone tell me for certain what the bulb # is for front and rear turn signals for the '02 model?
Old Jun 16, 2003 | 08:10 AM
I30tMikeD's Avatar
Looks like you did a good job with the tails....
Don't you have the one-piece head lights? If so then you can't see the corner bulbs?
Old Jun 16, 2003 | 06:22 PM
max5spd's Avatar
I bought the bulbs from here. They are a little pricey, but well worth it. Also, shipping is free. Now, here's the catch, they are not a direct fit. The two nubs are at 2:00 and 10:00, where US 1156 bulbs are at 9:00 and 3:00. I just grinded one nub off the bulb with a Dremel and it worked fine. I also bought my Philips H4 Vision Plus bulbs here. Guys, if you have Cefiro headlights or use H4 bulbs, these bulbs are a MUST HAVE. They are friggin bright even without HIDs. And they are a pure white. I love them.
With every purchase, you get a pair of 194 bulbs too. They work great in the city lights. Again, white, not blue, not yellow.
Old Jun 16, 2003 | 06:26 PM
max5spd's Avatar
Yup, I've got the Cefiros as well. You see the reflection of the orange which is what I didn't want.
Actually, a friend helped me on the tails. That's one MESSY job. We had this black goop all over us.
Old Jun 22, 2003 | 01:48 PM
ratledge's Avatar
Question: I have an '02 I-35. My front blinkers are 1156 or 1157? How about the front parking lights and the rear blinkers? The only reason I ask is that I've noticed people selling an almost exact duplicate of the Philips SilverVision (? not certain that is the correct name, but the bulbs that are silver until lit, when they glow yellow) in Sylvania brand that are not "euro-fit" - i.e. don't have nibs at 10 & 2, have them at 9 & 3 like American standard would be. They are only about $10 per pair, and seem to be identical (any comments from those that have tried them?)...
I want to replace all three sets, and remove my orange front side inserts, so I'll have nothing but clear & silver when I'm done, but I'll still have amber blinkers and parking lights when they are lit.
One question: I don't see any details about 'baking' the lenses up front - I assume it's likely about 175 degrees for 10-15 minutes to loosen them up and then just break them out of there - correct? I do have the one-piece (I'm pretty sure from looking) lens - even though mine are OEM (jump right in and correct me if I'm wrong, please!).
How about the rear bulbs - I haven't gone into the trunk spelunking, but assume that like most vehicles they can be removed by just opening the trunk and moving the proper piece of felt insert and accessing the bulbs from the rear (or am I in for more fun than I think?).
]RatMan[
Old Jun 22, 2003 | 07:44 PM
Kal's Avatar
Kal
]RatMan[
When i did a trial run at it with my extra headlight i had i baked it at about 250 for about 8 mins and that got it nice and loose enough for me to pull it off.
I did a write up, but im gonan re-write it when i get the chance.
http://forums.maxima.org/showthread.php?threadid=226730
Old Jun 24, 2003 | 06:16 PM
ratledge's Avatar
Well - it's a cheap trick - but on 'ebay' I found both 1157 and know I've seen the 1156 there as well. The ones they are selling are not Philips brand that have 9 & 12 pins instead of 10 & 2 o'clock euro-style bulbs, and they run $10-$12 per pair (using the "Buy it Now!" feature) plus shipping once you've found them. A whole lot cheaper than the $40/Canadian or 16# British + S&H I've heard people talk about for the Philips brand, and you don't have to mangle them with a Dremel to burn one of the pins off, either.
Frankly, no one has commented on the quality of them vs the Philips bulbs, so I'll have to get back to you once I've used them a while. I toasted my front lenses and snapped the orange part off the corners this past weekend, and put the 1157 silver bulbs in.
I should have had enough sense to check when I had those suckers pulled off but forgot in my zeal to get it all done: what bulb # goes into the parking light sockets? (I'm an '02 I-35)
Also - I didn't want to order any 1156's until I was certain I had that right for the specific ('02) model - are we on the same page?
If you can't find them, lemme know and I'll go ferret them out and give you a better hook!
]RatMan[
Old Jun 24, 2003 | 07:48 PM
Kal's Avatar
Kal
You cleared your headlights? Congrats. I hope my instructions kind of helped you out. Also how hard did you find it to be? The bulbs in the parking lights are 194's.
Well - it's a cheap trick - but on 'ebay' I found both 1157 and know I've seen the 1156 there as well. The ones they are selling are the Sylvania brand that have 9 & 12 pins instead of 10 & 2 o'clock euro-style bulbs, and they run $10-$12 per pair (using the "Buy it Now!" feature) plus shipping once you've found them. A whole lot cheaper than the $40/Canadian or 16# British + S&H I've heard people talk about for the Philips brand, and you don't have to mangle them with a Dremel to burn one of the pins off, either.
Frankly, no one has commented on the quality of them (Sylvania) vs the Philips bulbs, so I'll have to get back to you once I've used them a while. I toasted my front lenses and snapped the orange part off the corners this past weekend, and put the 1157 silver bulbs in.
]RatMan[
Old Jun 24, 2003 | 08:54 PM
ratledge's Avatar
Actually, the only hard part was figuring out that my head was dull and I shouldn't get touch them with my fingers! I don't bake my headlight covers that often };^) They came out pretty easily once I 'baked' them at 180 for about 10-12 minutes. I just used a cloth-covered large flat-head screwdriver and popped them loose off each of the three points on each side. The bulbs were easy and quick - just popped the OEM's out and put in the Silver w/amber glow jobbies I bought off 'ebay'.
194 - actually, I think I had seen that somewhere but just didn't remember for certain if that we 'me' (i.e. for the '02 model). Do you know if the 1156 bulb is correct for the rear turn signals on mine? (it sure looks like it is for a '96 model, but I haven't pulled them out and looked, yet.) One step at a time - obviously I'm going to go "full monty" but I'm taking my time. Will get the clear side markers next when I find out for certain if the ones I saw on "custommaxima.com" for $54 are 'right' for the I35 '02 model.
Old Jun 28, 2003 | 05:54 PM
ratledge's Avatar
I found "Euroda racing sport 'Type R'" 30 watt silvered amber 1156 and 1157 bulbs at http://www.hidking.com/silverseries.htm for $9.99 + $5 shipping.
Changing the rear bulbs (on my '02, anyway) was a five-minute job - just reach in the trunk, pull down the felt a little and twist the OEM bulb and pull it out, twist the assembly to actually remove and bulb and reverse the procedure with the new (1156 in my case) bulbs. Total elapsed time was 5 or 6 minutes...
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
