Removing foglights on '96 I-30t.
Old Jun 23, 2003 | 08:14 AM
Taxvictim's Avatar
How do you remove the foglight on a 1996 I-30t? One of my foglights has water in it. I removed the plate under the bumper, but could only reach one side of the bracket. It had a big plastic nut on it. Is that the only thing holding it to the bracket? Do these things just pop out?
Also, I finally got the plug out of the manual transmission and was able to top off the fluid. Needed a 1/2" socket wrench and a metal pipe as a leverage extender. If you want to change the fluid, where should you drain it?
Old Jun 23, 2003 | 10:24 PM
JsL's Avatar
JsL
Re: Removing foglights on '96 I-30t.
Taking out the fog light is soooo easy.
Remove the most left and most right light on the bumper next to the fog light by removing a screw that is easily seen with the bottom panals removed. When you look directly up, they are right there facing you near the cornering lamp.
After removing the screw, the corner lamp will pull off. If you haven't pulled it off before, it will take a little bit of force. Pull the corner lamps outward towards front of car.
After the corner lamps are off, you will see one screw holding the fog light in place.
There is no way to take off the fog light without taking off the cornering lamp.
Old Jun 24, 2003 | 06:21 AM
Taxvictim's Avatar
Thanks, I'll try it this weekend.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
