cefiro one peice question
Old Sep 28, 2003 | 02:49 PM
I30LeNnY96's Avatar
Hey my name is lenny. Im new to this forum and i am a new driver.
I have a I30 96 and i was to buy the cefiro one peice headlights.
I was wondering what i need to get them to work. ive been reading and from what i understood i cant use my stock light and i need to get HID?
IS this true? Please tell me everything you can.
My car is completly stock.
Old Sep 28, 2003 | 05:02 PM
I30tMikeD's Avatar
No you don't need HID. But what you need depends on what is included when you buy them. Required will be an H4 bulb and harness for the headlight. The other two stock lights can be used.
Old Sep 29, 2003 | 05:41 AM
Albertt's Avatar
Since your new...and untainted...here's some wise advice. Buy the Cefiro lamps and stick with the H4 bulb setup that it comes with. Buy yourself some good bulbs and enjoy your car. Like Mike stated above, you will need to convert your harness over to accept the H4 bulb. You will have to splice in the H4 connector in place of the 9004 connector.
Here's a picture of the difference between the two connectors:
http://www.fastforward.ca/Lights/Van...%20to%20H4.pdf
You're supposed to be able to buy the connectors here:
http://suvlights.tripod.com/suvlight...re-harness.htm
Old Sep 30, 2003 | 09:53 PM
Infiniti75_SA's Avatar
Hey, one thing you need to know that if you planned to get the cefiro one piece headlights certainly you will need H4 bulbs with high and low function in the same bulb, but if you get HID H4 system you will loose the high function, but there is a system of HID that provides high and low function through magnet on the bulb itself, where when you press the high beam the magnets on the bulbs act and gets inside and through the reflector in the bulb you can get the high effect. CATZ are a good system there is also POLAR type good quality. The good thing about this system it will look great on the cefiro headlights. Great match.
For the headlights speak to apple_sa@hotmail.com and tell him I sent you to him
Old Oct 5, 2003 | 06:28 PM
I30LeNnY96's Avatar
Thanx guys youve been a lot of help.
Oh and Infiniti75_SA i talked to apple_sa@hotmail.com, he was a lot of help.
Thank You
BTW i am interested in buying the cefiros, does anyone know how i can go about getting them. I think they sell them on this forum but i don't know who to ask.
Old Oct 6, 2003 | 03:34 AM
Drew96I30's Avatar
Thank You
check out www.paradox-systems.com that's where I got mine. He doesn't list them on his website, but he can order them for you. His name on maxima.org is "maxmojo".
Old Oct 6, 2003 | 12:47 PM
I30LeNnY96's Avatar
If i do this will i have the HI/LOW function?
Old Oct 6, 2003 | 12:59 PM
yes
the H4 comes with high and low functions, but but im mind to connect the three nodes in the harness...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
