Hey I30Mike and others: Another Cefiro Headlight question....
Old Nov 7, 2003 | 09:18 PM
USRacer900's Avatar
I bought them used so I don't know exactly what is supposed to come with them. They didn't come with the turn signal bulbs or the socket that the turn signal bulb fits in. I'm assuming I can use the original bulb and socket, however, the stock turn signal socket doesn't fit into the Cefiro turn lamp. I noticed that the old socket has three "nubs" and the Cefiro has four slots for them to fit into. I suppose I could dremel one "nub" down and maybe it would then twist in. Does this make sense??? Anyway, do they make a Cefiro socket for the turn bulb to fit into or what have you guys done to make this work?
Thanks again!
Old Nov 7, 2003 | 09:26 PM
InfiniSteve's Avatar
Yeah, you can use your originals .. Just use a utility knife to open another hole up to squeeze it through. Be careful though they cut easy and you want to keep a tight seal. You also probably want to keep the stopper. I ended up extending the right top hole around half inch just before the next hole down, to fit the big nub. Can't remember if I had to do any other changes,
Hope that helps,
Steve
Old Nov 7, 2003 | 09:31 PM
USRacer900's Avatar
Yeah, that's great. I'll get the dremel out and make another hole. Thanks a bunch Steve......
Old Nov 8, 2003 | 05:26 AM
I30tMikeD's Avatar
Steve is right about making the stock turn siganl bulb fit. I have explained how I did it a few times in other threads, a search would find those posts
RinconI30
Nov 10, 2015 10:55 PM
dcam0326
Sep 18, 2015 04:52 PM
Hdnseek
Sep 9, 2015 05:55 AM
DrVee
Sep 4, 2015 12:18 PM
sdotcarter
Sep 2, 2015 09:53 PM
