"Check engine soon" light is on.
Old Apr 5, 2004 | 05:43 AM
GeneK's Avatar
Showing 3 different codes...
"0304"
"0704"
"0903"
Evap system and knock sensor all went at once? Can one be the reason for the other codes to show up?
Thanks!
Old Apr 5, 2004 | 05:57 AM
I30tMikeD's Avatar
Yhea, it happens some times. Fix the cheapest or easiest one first then see what happens.
Old Apr 5, 2004 | 12:46 PM
nycspudz03's Avatar
I've got the same exact codes. Had them for about 5 months now. I'm replacing the knock sensor this week and see if that changes anything. If you have any ideas, let me know. I own a 97 by the way
Old Apr 6, 2004 | 05:15 AM
GeneK's Avatar
To Nycspudz03 !!!
Are you doing k/sensor at the shop? I'm in brooklyn too and I have silver '97 I30t. Let me know.
Old Apr 7, 2004 | 08:48 PM
Cussingboy's Avatar
Same thing happened to me, dealer needed to reprogram ECU. No Problem since
RQ
Old Apr 8, 2004 | 10:02 AM
edubz's Avatar
"0304"
"0704"
"0903"
Thanks!
hello my check engine light is also on, i have a 2000 i30t. How did you get those codes? My car has 53000 miles, is it normal for the light to come on? i need my car for work and I cant get it fix for another 5 days. is this dangerous to drive around. Car drives find as far as i can see.
how much will it cost to fix?
Old Apr 8, 2004 | 09:44 PM
JimboneI30t's Avatar
My "Service Engine Soon" light also came on a couple of days ago. I called the dealer and they said it should go off after a few trips and that it was most likely because the gas filler cap was loose (which it wasnt). Unfortunately, its still on so I'm debating whether to take it to the dealer. I'm hoping it will just turn off. I would be interested in getting my error codes though. That would help me troubleshoot more. Are you getting them from a dealer?
Old Apr 8, 2004 | 10:11 PM
I30tMikeD's Avatar
you 2k+ guys who can't pull their own codes can just go to autozone and they will pull them for you for free. If you really want to turn the CEL off there is info on that in the 5th gen forum FAQ's
Old Apr 9, 2004 | 05:11 AM
edubz's Avatar
Hi mike, can us 2k guys get our codes? I saw the tips on how to get them, does it apply to a 2k i30(t)'s?
Old Apr 9, 2004 | 06:59 AM
I30tMikeD's Avatar
No, just go to autozone and they will pull them for you.
Old Apr 9, 2004 | 07:01 AM
Asian_N02's Avatar
I got codes in my wife's car. The dealership fixed it for free because it was covered under warranty. They had to reprogram the ECU.
Regarding checking your own codes...it's much easier to go to Auto Zone. They can even "clear" it for you if you want them to. You just have to have a place to look up the different codes.
Old Apr 9, 2004 | 07:47 AM
edubz's Avatar
Hi, dont understand how autozone will do it for free... is that their policy or is it just if your cool with the guy? How is this service free? Is there any conditions for it being free? I just take it to autozone, say that my engine light is on, they do the work for free?
Please excuse my excitement, but The infinti dealer said it would take an hour, didnt ask if they charge for something like this.
Old Apr 9, 2004 | 07:52 AM
I30tMikeD's Avatar
Yes, they do it for free. It's a simple process that takes 2 minutes. They don't fix it the problem, they just tell you what is wrong. They do it in hopes you will buy the needed part from them.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Samedi
Aug 13, 2015 04:05 PM
