Stock Offset Chart:
Stock Offset Chart:
(Mike- you may want to add this to the I30/I35 FAQs)
Since this info is hard to find without search, I will post it here:
Nissan:
15" x 6.5" 95-99 SE/GLE 40mm
16" x 6.5" 97-99 SE 40mm
16" x 6.5" 00-01 SE/GLE 40mm
16" x 6.5" 00-01 GXE 40mm
17" x 7" 00-03 SE 45mm
17" x 7" 02/03 GLE 40mm
18" x 8" 350Z 30mm
Infiniti:
15" x 6.5" 96-99 I30 40mm
15" x 6.5" 96-97 I30t 45mm
15" x 7" Q45t 36mm
16" x 6.5" 98-99 I30t 45mm
16" x 7" Q45 40mm
16" x 6.5" 00-01 I30 45mm
17" x 7.5" Q45t 30mm
17" x 7" I30t 45mm
17" x 7" I35 40mm
17" x 7" I35 sport 45mm
17" x 7" G35 45mm
17" x 7" G35 sport 45mm
17" x 7.5" 02 Q45 40mm
18" x 7.5" Q45 45mm
18" x 7.5" M45 35mm
18" x 8" G35 coupe 30mm
Centerbore on all 89+ Nissan/Infiniti cars is 66.1mm.
Nissan:
18" x 8" 350Z 30mm
Infiniti:
15" x 7" Q45t 36mm
16" x 7" Q45 40mm
17" x 7" I30t 45mm
17" x 7" I35 40mm
17" x 7" G35 45mm
18" x 7.5" Q45 45mm
18" x 7.5" M45 35mm
Originally Posted by I30tMikeD
I know for a fact that my 96 BBS wheels have a 45mm offset.
And isn't the base I30 96-99 rim 15" x 6" and not 6.5"?
Edit: Done
Originally Posted by phenryiv1
Yeah, we need to add those AND the Q45 rims that I am looking at purchasing. I think that the I30 reference # on there is for non-"t" rims.
Edit: Done
Edit: Done
Originally Posted by max5spd
If my stock BBS wheels were 45mm and my current Q45t wheels are 30mm, would that explain the rubbing that I get? Would spacers fix that?
What width are the Q45 rims and what type of springs are you on? If you are are lowered 2" and the rims are 7.5" wide the 30mm offset could be causing the rubbing. Is it rubbing when turned or when going over bumps?
The Q45t wheels are 17x7.5 and I'm running on H&R springs. Generally, they ride fine UNLESS I have someone sitting in the rear and I hit a dip in the road. Even rough surfaces don't rub. Only dips.
It is not YOUR fault that you got a good deal...I hope that you did not up the price TOO much, but $300 would be reasonable for those rims...who cares what you paid for them- you found them, posted the link, and still bought them fair and square...you deserve whatever someone will give you for them...
I am glad you posted this though, now I know how much offset I can run w/o rubbing.
oh, what size tire are you running? is it stock diameter?
I'm running a 235. I was thinking that my next set would be 225 and help the rubbing a bit.
How does rolling the fenders work? Someone told me that I need an aluminum softball bat to roll it.
Originally Posted by JeffesonM
I've got the 17x7.5" Q45 wheels but I was told they are 32mm offset. I run 235/45 tires and get no rubbing with a drop on Progress springs (1.7/1.5)
Maybe that is why I30 offsets are 5mm more inset compared to rim size than maximas. A 4th gen maxima rims that is 6.5" has a 40mm offset and a 1st gen I30 with a 6.5" rims has a 45mm offset. Maybe there is a reason for that???
235/45/17 sized tires
Try something like this. Take a 2 foot section of a 2x4, or even a level would work, and set it vertically against the tire to see it it protrudes past the fender. It does not even have to go passed the fender, it just has to be out far enough to rub the inside of the fender. I bet your rear wheels just come out a tad too far and enough weight in the back combined with a small bump causes rubbing.
so, what do you recommend on how to fix?
There is not really anything you can do besides get a wheel with a higher offset or one that is 7" wide. I gues you found out for us that we can't run lowering springs with a 7.5" rim that has a 30mm offset. Sucks, but you just bought a rim with the wrong offset for our car.
You could look into rolling the rear fenders a tad.
How about a slightly skinnier tire? Like 225/45/17? I'm wondering if 10mm would make a difference. As for rolling, how do I do that? Take it to a shop or is there a cheaper (ghetto) way of doing it?
I don't know if the changing the tire size by only that much would do it or not. You really need to take some measurements and see how far out your wheel is. I don't know anything about rolling fenders besides what it is.
Looking at the offset calculator...
Assuming that my stock wheels were the BBS 15x6.5" with a +45 offset, and the wheels that I'm looking to get is 17x8 with a +35 offset, the calc says that the outside edge of the wheel will extend an extra 29mm. With my current setup, it says it will extend 28mm. Now what do I do? Does it matter that the new wheels are deep dish?
There is a guy on here w/ 5-spoke OZ Monte Carlo rims. THye are 17", but I do not knwo the rest of the specs. THey look a lot like the Type Es that you like. Want me to dig up the info?
Ok, I went to Autotrend today which is ROH's East Coast distributer. They were great. Rather than getting me to buy a set of wheels, they talked me out of it. They said that new wheels would still rub for me and they don't advise it. They said that my rear seems to have a lot more travel than most Maximas/I30s they've seen. My friend hit in on the head when he asked, "Don't you have those Motivatoinal mounts?" Of course! Those give me an extra inch or so of travel. That is what's causing my rubbing. The sales guy said to save my money, roll my fenders, and my problem should be solved. If rolling my fenders doesn't work, I'm going to take the Motivational mounts off.
You COULD always try to trade the Q45t rims for a set of I30t rims (just like the ones that you sold). The difference in offset might give you the tuck that you need.
17" x 7" I30t 45mm
The I30t are 1/2 inch more narrow (1/4 inch inset) versus the Q rims, plus 15mm less offset (about another .6 inches inset). You will be right around 3/4-1 inch in from where you are on the Q rims.
Did you ever get info on how to roll the fenders?
By the way, do you two ever feel like it is just the 3 of us having a conversation in ths forum?
Yeah, you, me, and Mike.
You're right, but I don't want to dish out any extra money for rims that look exactly like what I have now. Not to mention, I would have to buy new tires because I don't feel comfortable with a 235 tire on a 7" wheel.
As for rolling the fenders, the guy at the wheel shop said to use a rubber mallet and gently tap on the lip until it's flush with the back side of the fender. He said not to rush because I can crack the paint. He said it'll take at least an hour per side and a lot of patience.
I think I'm going to take it to the shop because I have some other work to do. I also want to cut the bumper so that my Y2k muffler looks right (oval muffler vs. round cutout) and I want to get the Siruius antenna painted to body color.
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
