name that pipe
Old Jun 8, 2004 | 05:54 AM
PhillyDonut's Avatar
name that pipe
does anyone have a pic of the under carriage of A32? Hayes manuel cuts off right in the center... where does the B pipe start from? does it start after the cat? does it have a canister attach or is it a straight pipe? any help is appreciated.
thanks,
pd
Old Jun 8, 2004 | 08:06 AM
NewLoveI30's Avatar
Yes, I believe that the B-pipe bolts up after the cat... Well there is probably a gasket between them
Sorry I dont have a pic. I dont have an A32.
Old Jun 9, 2004 | 04:32 AM
Do you know if there's a canister attached to the front of the pipe? between the Cat and B pipe or is it just a straight pipe/tube?
Old Jun 9, 2004 | 08:30 AM
NewLoveI30's Avatar
A resonator?... Im not sure. I would look for you, but like I said, I dont have an A32.
You could search for an A32 exhaust diagram. If I find something I will try and post it.
Old Jun 9, 2004 | 09:41 AM
don't have privilege to search... but would greatly appreciate it if you could post or send me a pic.
thanks.
pd
edit: does anyone know if the aftermarket B-pipe is just the pipe? or does it have the "resonator" as well?
Old Jun 9, 2004 | 05:40 PM
i30ds's Avatar
Armed and Dangerous
thanks.
pd
The B pipe is actually two pipes. The first is a very small pipe that has an oxygen sensor in it. Then come the actual b pipe, which has the resonator (the can). After that of course is the muffler. You can remove the b pipe from the cat with the smaller pipe attached! I was just an idiot when I removed mine! But any ways, Cattman makes a VERY good B pipe. It comes with a large high quality resonator and has smooth (no crimps) 2 inch piping the whole way. Plus, it is stainless steel!! The resonator Also has a hole for the oxygen sensor. This is a direct fit!!
Old Jun 10, 2004 | 08:20 AM
Thanks, that was helpful. A few more questions.
How much bigger or smaller is the resonator on the Cattman B pipe compared to stock (i'm hoping it is smaller b/c mines scrapes with my drop)? Do you know if there are straight B-pipes without the resonator (straight pipe)? How much does it cost compare to a cat-back exhaust? Did you consider a cat-back exhaust before going with just the B-pipe? I'm actually considering just the B-pipe for the non-noticeable look.
Thanks,
pd
Old Jun 13, 2004 | 07:28 PM
i30ds's Avatar
Armed and Dangerous
Thanks,
pd
Well actually, the cattman resonator is larger and higer quality, but it DOESNT hang down as low as the stock one. I had the same problem bottoming out my stock resonator on the speed bumps outside my apartment complex! After I put in the after market resonator, it never happened again!
Stillen actually makes a b pipe that is straight through, but I dont know if you want to go that route, especially if you dont want to be noticed! Removing that resonator will make your exhaust loud as hell, and it will gain you little hp!
I think cattmans b pipe is $300. If you add their high performance muffler for $350, you will then have the cat-back system! I purchased the cat-back system, but the muffler was a little too loud at the lower RPM range, and so I kept the b pipe, and put the stock muffler back on. The muffler that cattman sells is just a striaght through glass pack which has no baffles to quiet the exhaust down. My advice would be to buy their b pipe, but keep the stock muffler, that way you still have that non-noticeable look! Plus, if you want to get an after market muffler later on, you can go to a muffler shop get one that is more free flowing, but retains a quality sound that is pleasing to your tastes!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
