weak hp gain?
Old Sep 12, 2004 | 08:51 PM
cefiro8701's Avatar
weak hp gain?
okay...on saturday(since the forum was down) i went to maxima racing...and i read the mods section...they kept on saying that the CAI would only add 1-2 horsepower and that HAI would harm the engine?tell me thats not true!! i was planning on buying the mods soon...but not when its only for sound...
Old Sep 12, 2004 | 09:05 PM
I30tMikeD's Avatar
no, it's not a big power mod. It will give you a few extra ponies but it's nothing to brag about. What do you mean by "hurt" the engine. It doesn't cause damage if that is what you mean.
Old Sep 12, 2004 | 11:34 PM
cefiro8701's Avatar
i dunno what they mean...i know its not a hp bragger...but just a couple of horses for 70+$??? wtf?!
Old Sep 12, 2004 | 11:36 PM
cefiro8701's Avatar
does anyone have factual proof of what has the highest gain?what brand atleast?and if all this is right...i can only bring my car up to 230 w/ bolt-ons?
Old Sep 13, 2004 | 04:50 AM
I30tMikeD's Avatar
Yep, hp isn't cheap.
Old Sep 13, 2004 | 08:53 AM
v6maximus's Avatar
only up to 230? Man, I took it to 250 KP/h more then once, and I'm basicly stock!!! You must be doing something wrong I guess, or weigh over a ton!
Old Sep 13, 2004 | 09:24 AM
I30tMikeD's Avatar
200-210 with bolt-ons...wheel hp that is.
Old Sep 13, 2004 | 02:02 PM
i30ds's Avatar
Armed and Dangerous
I got a 5whp gain after I put on only a Stillen popcharger (which is just the cone and STOCK mid pipe). Then, I got a 18whp gain after I put on the Cattman Y pipe. Finally, I got a 6whp gain after I put on the Cattman b pipe. For a total of 29whp gain which if measured at the crank, would be maybe say 35bhp.
GET THE CONE.... it will not hurt engine performance. The stock set up would be like trying to breathe through a straw. Plus, the new growl from the engine will be quite pleasing.
Old Sep 13, 2004 | 03:09 PM
I30tMikeD's Avatar
So what did your last dyno look like? Have any pics of the graph or at least peak tq and hp #"s.
Old Sep 13, 2004 | 04:10 PM
i30ds's Avatar
Armed and Dangerous
I don't have a scanner or anything fancy like that, but in a nut shell the dyno graph showed practically the same hp as stock up to 3000 rpms. After that, the band slowly makes more and more power with max whp of 184 @ about 5250 rmp. The peak did not appear to shift in the power band much. Maybe a couple hundred rpm. The tq was was like the hp in regards to the original curve. The last run vs the stock run was about the same (maybe only 7 ft/lbs higher) up to about 3200 rmps after that, last run pulls drastically from the stock and reaches a max of 189 @ about 4600 rpm.
This seems to make sense to me as during daily driving the does not feel that much quicker, up to 3000 rpm. But for impromptu races, and track runs, you really feel the difference from stock. If a tq brake to about 2000-2500 rpm, I get some good tire squeel of the line and with disconnecting the VB, I get it into 2nd as well.
Maybe I can have Kinkos scan these on to a disk and then I can create a link on my sig for people to look at.
What did your dyno run look like? I read that you said it was disappointing....
Old Sep 13, 2004 | 04:36 PM
I30tMikeD's Avatar
The basic type of bolt-ons that just take advantage of better flowing intake air and exhaust gases won't give low end gains.
So your at 184hp and 189tq if I read your post correctly? Man if you did a 5spd swap you would be putting down some good #'s. I would like to do some pulls on your dyno.
I had problems with power drop off after 6K rpms which shouldn't happen with my MEVI...I was loosing 25whp from 6K to 7200 where as I should be loosing about 4-5 hp. My MEVI wasn't operating correctly either.
I fixed the MEVI activatioin problem and think I found the power loss problem as well. There is a long 4 page thread about it in the general forum. Read the last 6 or 7 posts to find the conclusion. I did end up getting some decent #'s and a correct looking power curve.
Old Sep 15, 2004 | 12:34 PM
i30ds's Avatar
Armed and Dangerous
Even a SC would not give you gains below 3000 rpms. I don't know of any mods that will either, except maybe a lighter flywheel or do the 70mm Pathfinder TB. Did you get any noticeable gains from your TB mod?
My guess is that if I SC first, I will put down maybe 255whp and 225wtq. However, if I drop in a manual I will maybe only put out 200whp and 205wtq
Old Sep 15, 2004 | 12:39 PM
I30tMikeD's Avatar
The type of SC that we use won't. Increasing the displacement or inreasing the compression should. But not your basic bolt on.
You want to buy my PF TB? It is for sale.
Old Sep 16, 2004 | 01:35 PM
i30ds's Avatar
Armed and Dangerous
I have always wondered what gains one could get from doing the 3.3L stoking of the VQ by using the 3.5L crank and rods. Maybe 20 hp or 20 tq down low, below 3000 rpms. What do you think? Guys on the 4th gen forum have done this, but I personally never saw any dynos of the stroking.
I am interested in your TB. Is the 70 mm TB mod that you have done also the pathfinder TB. Does it come with the adaptor plate? Did you get any gains from it, or more specifically, did you recieve any better throttle response? How much are you asking?
Old Sep 16, 2004 | 02:15 PM
I30tMikeD's Avatar
Nobody that I know of has done the 3.5 internals into a 3.0....I even think that upon more investigation that it is not as simple or even doable as first thought. Now the 3.5 bottom end with 3.0 heads is very doable and was recently done by a 4th gen owner
My throttle body is the 70mm Pathfinder one. Stock is 60mm. I am selling it with the adapter plate, gasket, hardware...everything you need. I did not do a dyno comparison so I cannot claim X amount of power but I think it helped my top end. Throttle response got a little bit better, but nothing that hurts driveability. I honestly thought it was going to make the throttle too touchy but it feels almost like stock. This mod does not change the driveability of the car at all. I am asking $275, which I am firm on. this is for a 01 throttle body, custom adapter plate that allows you to keep your cruise control (there was another adapter plate that was made that did not allow cruise control to work), all the bolts, the adapter to bypass the coolant lines, the metal pathfinder TB gasket, and custom gakset for the adapter plate.
Old Sep 17, 2004 | 01:35 PM
i30ds's Avatar
Armed and Dangerous
Hmmm... I am seriously, seriously interested. The price seems quite agreeable. I was wondering how many miles you drove on it, and the reason you are selling it? Was there something in particular that you did not like?
Also, I read in the 4th gen stickies that because the new TB is larger in diameter, you must remove the intake manifold and "shave down" the first several inches down the manifold walls inorder to make the TB fit up against it flush. Would I still have to do this or does the custom adaptor plate compensate for the difference in diameters?
Old Sep 17, 2004 | 01:52 PM
I30tMikeD's Avatar
Sold it last night
Old Sep 17, 2004 | 01:55 PM
i30ds's Avatar
Armed and Dangerous
Sold it last night
NOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
Old Sep 23, 2004 | 06:52 AM
v6maximus's Avatar
Yep..........
Old Sep 23, 2004 | 01:24 PM
i30ds's Avatar
Armed and Dangerous
Originally Posted by v6maximus
Yep..........
Are you the one that bought it?!?
Old Sep 23, 2004 | 01:25 PM
I30tMikeD's Avatar
No, it wasn't him.
spencerwh1
Jun 30, 2016 05:44 AM
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
