how can I tell if an i30 has an LSD manual?
Old Sep 29, 2004 | 08:35 AM
Redmax's Avatar
Redlinemax Owner
its a 98 I30 that I found at the junkyard. How can i tell if the tranny is LSD?
Old Sep 29, 2004 | 08:47 AM
Zack342's Avatar
there is a tranny code on the transmission block also if the tranny is still in the car check the VIN
Old Sep 29, 2004 | 09:54 AM
Redmax's Avatar
Redlinemax Owner
I have the vin. I called the Stealership and they said that the Vin doesn't tell the type of tranny Weren't all 98 i30's lsd?
Old Sep 29, 2004 | 10:32 AM
i30ds's Avatar
Armed and Dangerous
those gus are a bunch of morons. Look at the tranny code on the firwall plate. I think if the forth or fifth character is a V, then it is a viscous LSD. If it is an A, then it is no viscous LSD.
i30tmiked knows for sure...
Old Sep 29, 2004 | 10:41 AM
flthere's Avatar
http://www.infinitihelp.com/vin.htm
seems the VIN does not have the LSD info built into it!
Old Oct 15, 2004 | 03:28 PM
2000Infinitii30's Avatar
Ok stupid question ... what the hell is a lsd Transmission?
Old Oct 16, 2004 | 05:43 PM
SYCEFIRO's Avatar
VLSD= Viscous Limited Slip Differential
LSD= Limited Slip Differential
Old Oct 18, 2004 | 01:21 PM
i30ds's Avatar
Armed and Dangerous
It is a LIMITED SLIP DIFFERENTAIL. That mean that both wheels can have power to them when slippage is detected. This helps with cornering, take offs, and acts as traction control for snow and rain. It is a very GOOD thing. It was standard on the t models.
The most common diff. on the I30 was the open end type, in which only one wheel at a time has direct power to it. The power of course does switch from wheel to wheel given the circumstances, but it is still only "one wheel drive"!
The real question is what the hell is the difference between a Viscous LSD (on I30t, and 350Z), or say a Helical LSD (optional on the 02-03 Maximas)?
Old Oct 18, 2004 | 02:51 PM
I30tMikeD's Avatar
You should be able to tell by looking at the splines where the axel goes into the tranny. I am only like 50% sure on this, but I think the VSLD tranny has stepped splines....I know they are different but I can't remeber exactly how they are different.
Old Oct 18, 2004 | 02:52 PM
I30tMikeD's Avatar
IIRC the viscous uses a fluid to transfer the power and helical is mechanical. The viscous being less efficient.
Old Oct 18, 2004 | 04:38 PM
i30ds's Avatar
Armed and Dangerous
Fluid eh... hence the name "viscous". So why would the '03 Maxima get the better helical, and the '03 350Z get the less efficient viscous?
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
uttadms31
Sep 30, 2015 05:24 AM
