paradox parts install...
they said that you need some kind of alcohol based cleaner for the installation of many things...where would i get this stuff from?also they spoke of some kind of 3m primer so the tape will stick on perfectly.
SY
sycefiro@yahoo.com
Cefiro8701: The 3M sticky tape they are refering to is made my the company 3M. A lot of car parts that are meant to stick on to the car such as the sunroof wind deflectors, the ventvisor rain and wind window deflectors and other parts almost all use 3M tape. you can get a roll of this usually at the parts store and then cut what you need for whatever you are doing.
Paradox-Systems mirror LED shells come with the 3M tap already in place so all you have to do is take the protective backing off and then stick it on.
The cleaner stuff is just what SYCEFIRO said. Basically just put the Rubbing Alocohol on a cloth or whatever and clean the surface you need the 3M to stick to. Rubbing Alocohol will dry quickly and basically evaporate off of whatever you put it on leaving it free of oil or dust or fingerprints, etc. Basically it gives you a very clean surface for the 3M to stick securly to. You could also use the alocohol wipes. Either way it just helps the adhesion process.
excellent....another question...why do our "TITLES" still say maxima stuff like...max fanatic and maxaholic and other max related stuff when they should all know we love our 30s....??
Yes, you should think of your I30 as an overseas maxima. Ever see the picture of the Iraq police in their maximas?http://www.ccmep.org/2003_articles/I...eak_up_ira.htm
or an Australian maxima?http://www.autoweb.com.au/cms/usedca...4/vehicle.html
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
