Cold Start Problem
Old Jan 14, 2005 | 12:37 PM
anton9881's Avatar
Cold Start Problem
My car starts fine in the cold weather but when I put it into gear, it dies as soon as I let off the gas. I have to let it warm up until the needle is atleast at the C for it not to die on me. What is causing this problem?
Old Jan 14, 2005 | 01:33 PM
Double E's Avatar
Minnesota.
Couldn't resist. Seriously though, it sounds like it could be a couple of different things. Start with the cheap solutions first.
I would start by adding a bottle o' injector cleaner and follow it up with a bottle of dry-gas at the next tank. Of course, this may not give you the results you want as soon as you want them. (I was 16 also).
Beyond that and I'm thinking TPS, fuel pump or crank shaft angle sensor, o2 sensors, wires or a host of other stuff that can get expensive.
Does the CEL light ever come on?
Also, give us the year & trim model.
Old Jan 14, 2005 | 08:07 PM
raybone97-I30t's Avatar
clean your throttle body, both sides of plate and as far back as you can reach,,,SHOULD fix it...it worked for me, and many others here...
Old Jan 14, 2005 | 10:00 PM
anton9881's Avatar
I know I need a new O2 sensor, crankshaft position sensor, and to clean my throttle body. Do you guys think doing all that will solve my problem?
Old Jan 17, 2005 | 11:43 AM
Double E's Avatar
Yup. Raybone is on it.
If you already know you need the CPS & o2 sensors, clean out that TB like Raybone said & you'll smile for all the $ you saved.
Old Sep 26, 2011 | 03:20 PM
jetsfanez's Avatar
My max is taking 6 secs to start every time, and i changed every sensor.
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
