Stillen or cattman?
Old Apr 10, 2005 | 10:50 AM
Pimpnyc3's Avatar
Stillen or cattman?
I'm looking to purchase the front stru tower and rear sway bar for my 1997 Infiniti I30. Cattaman performance and Stillen both have this item. In your opinion which brand is better to purchase. Stillen or Cattman that is the question? Thanks
Craig
Old Apr 10, 2005 | 02:13 PM
cefiro8701's Avatar
ebay...pay 10 dollars
Old Apr 10, 2005 | 02:34 PM
steven88's Avatar
Need A Light?
I would pick the Cattman....becuz it is made out of polished titanium....wheres the stillen is made out of polished aluminum....
i'm sure your goal is to get the most BLING factor out of your FSTB.....becuz your two choices are the most expensive FSTB out there....so out of those two.....Cattman is the only way to go if you want the "bling" factor.....everybody would go once you tell them its polished titanium....
As for the RSB....get the stillen...it is adjustable with no rear bushings as with the cattman one....the cattman is obviously alot cheaper....and both do the same work.....but since i know your into the bling....Stillen all the way
Old Apr 10, 2005 | 03:18 PM
roofadoofalus's Avatar
bling it is
Old Apr 10, 2005 | 07:34 PM
skeetch's Avatar
Craig
Get the stillen RSB, you won't regret it . I put one on about 2 weeks ago and car rides flatter in the turns. One thing about the stillen setup though...and I am not sure if anyone else had to do this but I had to modify the ABS brackets in order to install the RSB. Otherwise the stillen brackets that mount to the rear axle control arms would not sit properly. (Not sure if this will have to be done on a '97) Now I want a FSB but doesn't seem like they make one. I might wind up getting the FSB from an I30T since the have a slightly thicker bar. As for the FSTB I'd go with the Cattman.
Old Apr 12, 2005 | 04:25 PM
i30ds's Avatar
Armed and Dangerous
No modifications are needed on the 97 Stillen RSB... the mod is 100% bolt on with all materials provided along with instructions...
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Stagnet04
Sep 14, 2015 11:28 PM
