passenger’s seat heater is not working, need your help
Old Feb 27, 2006 | 05:19 PM
i30ish's Avatar
My passenger’s seat heater is not working. The light on the switch works though. I’ve checked the fuse and it’s good. I know that some liquid was spilled by a previous owner on to the switches. Any tips on where to look for possible cause? And if you say switches, what's the best way to take them out? Thanks.
Old Feb 27, 2006 | 05:46 PM
NewLoveI30's Avatar
I would look more towards the heating element myself. I know I had one go out on my old SAAB, but that was after about 90k/10 years.
The switches would be easier to check though... Just take a flatblade or a knife works too. wrap it in a cloth so not to scratch the surrounding material, and pry the switches up from the edge.
Old Feb 27, 2006 | 05:59 PM
i30ish's Avatar
So if the light shows up, the switch still can be malfunctioning ?
Old Feb 27, 2006 | 06:24 PM
NewLoveI30's Avatar
I would really doubt that, but I've been wrong before. An easy way to check would be to switch the switches (sounds funny, I know). Just unplug the wires to the passenger switch and use the drivers switch. If passenger warmer works, it was the switch.
Like I said, I really doubt this is the problem. Look at replacing the heating element.
Old Feb 27, 2006 | 07:59 PM
i30ish's Avatar
Thanks! i wouldn't think of that. I'll try that first thing tomorrow.
Old Feb 28, 2006 | 02:11 PM
i30ish's Avatar
So today I took out both of the switches and inspected the wires and the connector, looked fine. Then I disconnected both switches and tried to swap them, since driver’s side heater was working. Turned out you CAN’T swap switches because slots for connectors are different. So I took the switch apart, and discovered that all the metal parts inside are coated with all sort of sticky stuff. I cleaned everything out, reassembled the switch and what do you know, my A$$ began to worm up. I'm so proud of myself
Old Feb 28, 2006 | 04:14 PM
NewLoveI30's Avatar
Glad everything is working again!
Was this sticky stuff grease or something spilled down there? I know I had to take apart the window switches on my last car cuz a friend spilled coke all over the console.
I bet you're happy you didnt have to replace the heater. They are considerably more difficult to replace.
:edit: and you may want to have those worms on you a$$ checked out
Old Feb 28, 2006 | 06:00 PM
i30ish's Avatar
I'm think it was coffee. because i have stains elsewhere. I sure am happy it's not the heater, but if it was, i doubt i would replace it. Too much $$, for a little laxuary that worms my passenger’s a$$.
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
george__
Aug 18, 2015 07:06 PM
kenc15
Aug 5, 2015 08:29 AM
